HP Elite x3 Privacy Screen
Quicklinx: C94ZWS00 Mfr#: W8W96AA
Keep the visual eavesdroppers at bay, whether you're working with your HP Elite x3 on the go or in a fixed location, with the HP Elite x3 Privacy Screen, which also retains your touchscreen interactivity.
  • No peeking
    Maintain onscreen clarity and touchscreen interactivity with a privacy filter that prevents passersby from catching a glimpse of your work by blocking peripheral views of the screen.
  • Durable design
    Get the added flexibility of a filter that resists scratches, fingerprints, and smudges and helps protect your HP Elite x3 screen from scratches and nicks.
  • Easy application
    Use and reuse as needed with the adhesive backing that leaves no residue. The included cloth and wedge make it easy to wipe down the screen and smooth out any bubbles.
  • No cutting or resizing required
    Experience a precise fit with a rounded-edge screen that doesn't block access to your HP Elite x3's camera, speakers or inputs.
  • World-class support
    Rest easy with a one-year limited warranty.
HP - screen privacy filter
Screen privacy filter
Intended for
Mobile phone
Protection
Scratch-resistant, smudge-proof, fingerprint-proof
1-year warranty
Elite x3
Intended for
Mobile phone
Protection
1 year
HP Elite x3
