Keep the visual eavesdroppers at bay, whether you're working with your HP Elite x3 on the go or in a fixed location, with the HP Elite x3 Privacy Screen, which also retains your touchscreen interactivity.
No peeking
Maintain onscreen clarity and touchscreen interactivity with a privacy filter that prevents passersby from catching a glimpse of your work by blocking peripheral views of the screen. -
Durable design
Get the added flexibility of a filter that resists scratches, fingerprints, and smudges and helps protect your HP Elite x3 screen from scratches and nicks. -
Easy application
Use and reuse as needed with the adhesive backing that leaves no residue. The included cloth and wedge make it easy to wipe down the screen and smooth out any bubbles. -
No cutting or resizing required
Experience a precise fit with a rounded-edge screen that doesn't block access to your HP Elite x3's camera, speakers or inputs. -
World-class support
Rest easy with a one-year limited warranty.
- HP - screen protector for mobile phone
- Product Type
- Screen protector - with privacy filter
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, smudge-proof, fingerprint-proof
- 1-year warranty
- Designed For
- Elite x3
- Product Type
- Intended For
- Mobile phone
- Protection
- 1 year
- Designed For
- HP Elite x3
