HP Elite x3 Desk Dock
Quicklinx: C94RWS00 Mfr#: V5H01AA
Reinvent your desktop workspace with the ultra-compact HP Desk Dock, which quickly charges your HP Elite x3 and uses its pocket-sized PC power to maximize your Windows 10 Mobile productivity on an external display, keyboard, and mouse.
  • Multi-task with seamless multi-screen flexibility
    Talk, text and run mobile apps on your docked HP Elite x3 while simultaneously multi-tasking with your Windows and corporate apps on a connected external display using Windows Continuum and your app virtualization software.
  • Add your network and your accessories
    Connect to a wired network through the HP Desk Dock's Gigabit Ethernet connection and your choice of input/output devices and accessories with two USB-A ports and one USB-C port.
  • Charge up
    Get back to full battery power while you work when you quick charge your HP Elite 3x in the HP Desk Dock.
  • Travel light
    Simplify your day with one device. The HP Desk Dock lets you use your HP Elite x3 in and out of the office and easily dock at work and home for a complete desktop experience.
  • Integrated security
    Use the security lock slot and your own lock (sold separately) to secure your dock to another device, desk, or table.
HP Desk Dock - docking station
Docking station
10.8 cm x 9.5 cm x 3.05 cm
450 g
English / United Kingdom
Power adapter AC 120/230 V (50/60 Hz) 45 Watt Power Provided
1-year warranty
Elite x3
Docking station
10.8 cm
9.5 cm
3.05 cm
450 g
1 x display / video - DisplayPort , 2 x USB - USB - 4 pin USB Type A , 1 x USB-C - USB , 1 x network - Ethernet - RJ-45 , 1 x power
1 x power adapter kit - 1.5 m , 1 x USB-C cable - 1 m
Power adapter
Power Provided
45 Watt
Limited warranty - 1 year
HP Elite x3
C94R C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
C94R C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
