HP Elite x3 3-in-1 Phone Qualcomm Snapdragon 820 4GB 64GB 5.96" Windows 10 Mobile + Desk Dock
CLEARANCE!
Clearance
Quicklinx: C94CWS00 Mfr#: Y1M46EA#ABU
  • microSDHC
The HP Elite x3 is HP’s newest mobile device, carefully designed to combine PC power and productivity, tablet portability, and smartphone connectivity all in one handheld device.
Enhance productivity and mobility in the workplace with the Elite x3 and Windows Continuum1. Users can effortlessly switch between a handheld phablet, and a desktop PC or laptop experience when they dock to a larger display.
Experience the power and productivity of a PC, the portability of a tablet, and the connectivity of a smartphone in the palm of your hand with the HP Elite x3, HP's first built for business 3-in-1 device. It's designed to deliver simple and seamless access to your people, apps, and data.
The handheld HP Elite x3 is an easy and convenient way to work, in the office and on the go. Start a task on the go and finish at your desk without saving, syncing or restarting with the HP Elite x3, Microsoft Continuum, and optional docks, which allow you to work with a larger display. Crafted for business users, the HP Elite x3 is a robust device with powerful processing power, a long-life battery, dual biometric scanners, and dual SIM card slots. With HP Workspace, virtualize the business critical Windows x64 and x86 apps you rely on to get the job done.
  • Built for business
  • Enterprise security to reinvent the way you work
  • A stellar multimedia experience
  • The new mobile revolution
  • Superb manageability and value
    Enable IT to reduce the combined footprint of devices and operating systems and drive mobile employee innovation with the HP Elite x3, which helps boost your return on your IT investment and employee satisfaction and productivity.
  • Simplify your IT
    Make device and app management easier than ever with a single device that leverages your existing Windows infrastructure and can replace a separate smartphone, tablet, and PC.
  • Engineered to endure
    The HP Elite x3 is a robust device thoughtfully designed to perform in even the most challenging environments. It has passed MIL-STD 810G testing and is IP67 rated for dust and water resistance.
  • Optimized for business collaboration
    Enjoy clear conversations with premium audio by B&O PLAY, dual front-facing speakers, active noise cancellation microphones, and an 8 MP front-facing camera that's great for Skype for Business conference calls.
  • A high level of security
    Help secure your data and apply corporate security policies with integrated hardware and software encryption, and iris and fingerprint authentication.
  • Turn every room into a screening room
    Project your slide show, video, product demo, and more to a larger screen through the integrated Microsoft Miracast technology.
HP Elite x3 graphite with chrome - 4G smartphone - 64 GB - GSM - with HP Desk Dock
4G smartphone
Display
OLED display - 2560 x 1440 pixels - 5.96" - 494 ppi - AMOLED - Corning Gorilla Glass 4 (scratch resistant glass)
Qualcomm Snapdragon 820 2.15 GHz (quad-core) - 64-bit
Graphics Accelerator
Qualcomm ADRENO 530
RAM 4 GB / 64 GB
Supported Memory Card
microSDXC slot - up to 2 TB
Operating System
Windows 10
Main Camera
16 Megapixel focus: automatic
Front Camera
8 Megapixel f/2.2
Service Provider
Not specified
SIM Card
Nano SIM
Wireless Interface
NFC, Bluetooth, Wi-Fi 5
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Wireless Charging Standards
WPC, PMA, Qi
Bundled with
HP Desk Dock
Protection
Dustproof, waterproof
Graphite with chrome
83.5 mm x 7.8 mm x 161.8 mm
194 g
1-year warranty
Smartphone
Touch
Protection
83.5 mm
7.8 mm
161.8 mm
194 g
Body Colour
Bundled with
HP Desk Dock
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Windows 10
Navigation
GPS
SIM Card Type
Nano SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE, LTE Advanced
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 3, Band 19, Band 20, Band 26, Band 28, Band 38, Band 39, Band 40
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300
Wireless Interface
NFC, Bluetooth 4.0, IEEE 802.11a/b/g/n/ac
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, gyro sensor, hall sensor, pressure sensor
Security Devices
Fingerprint reader
Additional Features
Wi-Fi Miracast, Audio by B&O PLAY, Snapdragon Audio + support, 3 integrated omni-directional microphones with HP Noise Cancellation Software, ENERGY STAR certified
Clock Speed
2.15 GHz
Processor Core Qty
Quad-core
64-bit Architecture
Graphics System
Qualcomm ADRENO 530
RAM
4 GB
Internal Memory Capacity
64 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 2 TB
Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.2
Video Resolutions
1920 x 1080 (1080p)
Main Camera
Sensor Resolution
16 Megapixel
Focus Adjustment
Automatic
Light Source
LED light
Video Resolutions
1920 x 1080 (1080p)
Display
OLED display
AMOLED
Diagonal Size
5.96"
Display Resolution
2560 x 1440 pixels
Display Format
QHD
Pixel Density
494 ppi
Protection
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
Lithium polymer
4150 mAh
Wireless Charging
WPC, PMA, Qi
MIL-STD 810G, IP67
Headset, power adapter
Limited warranty - parts and labour - 1 year
