HP Elite x2 G4 Intel Core i5-8265U 8GB 256GB SSD 13" Touch Windows 10 Professional 64-bit
Quicklinx: G2F1WS00 Mfr#: 7KN89EA#ABU
  • Core i5
  • IEEE 802.11n
Get the best of both worlds with the freedom and agility of a tablet and full PC performance. Backed by hardened security the HP Elite x2 delivers the performance and versatility you need while protecting your assets.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • HP Sure Sense
    Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
  • Fast and efficient wireless LAN
    Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax).
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen5 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Protect critical security processes
    Keep your critical applications and processes running even if malware tries to shut them down with the self-healing protection of HP Sure Run.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
HP Elite x2 G4 - 13" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) - 8265U / 1.6 GHz, up to 3.9 GHz / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - NVMe, TLC, HP Value
Display
13" WLED touchscreen HP SureView 1920 x 1280 / WUXGA+
Graphics
Intel UHD Graphics 620
Input Device
Detachable keyboard, ClickPad
Keyboard
Keyboard Backlight
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
2-cell - up to 12.25 hours
Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor, electromagnetic compass
Security
Trusted Platform Module (TPM 1.2) and firmware (TPM 2.0), fingerprint reader
Dimensions (WxDxH) - tablet
28.93 cm x 21.58 cm x 0.88 cm
830 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8265U / 1.6 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), triple-level cell (TLC), HP Value
Display
13" - IPS
LCD Backlight Technology
WLED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Image Brightness
1000 cd/m²
Colour Gamut
72%
Privacy Technology
HP SureView
Ultra Slim Design, privacy filter, WUXGA+ ultra wide-viewing angle (UWVA) BrightView eDP +PSR, Corning Gorilla glass 5
Keyboard Name
HP Collaboration Travel Keyboard
Audio & Video
Graphics Processor
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Volume control, multi-touch clickpad, gesture function, precision touchpad, glass clickpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Miracast, dual stream (2x2)
2-cell lithium polymer
47 Wh
Run Time
Up to 12.25 hours
AC Adapter
Input
Output
65 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
Interfaces Details
USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB-C 3.1 (supports Thunderbolt) , Headphone/microphone combo jack
Software
Software Included
HP Support Assistant, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Client Catalog, HP BIOS Config Utility, HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Connection Optimizer, HP Manageability & Integration Kit Gen3 (free download), HP BIOSphere Gen5, HP Cloud Recovery
Integrated Options
Security
HP Automatic Drive Lock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Secure Erase
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Keyboard, USB-C power adapter
CSA, UL, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
Localization
830 g
Dimensions (WxDxH) / Weight Details
28.93 cm x 22.19 cm x 1.42 cm / 1.17 kg - tablet with keyboard , 28.93 cm x 21.58 cm x 0.88 cm / 830 g - tablet
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
G2F1 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £179.49
G2F1 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £247.55
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
G2F1 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £117.41
Other bundles (2)
G2F1 HP USB-C To VGA Adapter In Stock £22.09
G2F1 HP USB Travel Mouse In Stock £9.20
