Win the day with full PC performance and unleash creativity with the freedom of a tablet. Powerful processors handle your professional apps while tablet mobility lets you keep working on the go. The Elite x2 1013 delivers on the promise of the detachable device.
Creativity without compromise
Powerfully handle your professional apps with this incredibly thin and light 13-inch detachable business PC. Get a pure tablet experience with the optional HP Rechargeable Active Pen. -
Designed to bring people together
Huddle with the team or connect across continents. Collaboration is built into the DNA of the HP Elite x2 1013, equipped with premium audio, high-resolution cameras, and a world facing mic. -
Keep wandering eyes at bay
Help protect your PC from outside threats with a comprehensive suite of security tools. Keep prying eyes away from your creations on the HP Elite x2 1013 with the optional HP Sure View Gen2 integrated privacy screen and the HP Sure View app in tablet mode.
- HP Elite x2 1013 G3 - 13" - Core i5 8350U - 16 GB RAM - 512 GB SSD - 4G LTE - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) 8350U / 1.7 GHz (3.6 GHz) / 6 MB Cache
- Memory
- 16 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 13" LED backlight touchscreen 3000 x 2000 / 3K2K
- Graphics
- Intel UHD Graphics 620
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Service not included
- Battery
- 4-cell - up to 10.5 hours
- Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor, hall sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Dimensions (WxDxH) - tablet
- 30 cm x 23.15 cm x 0.79 cm
- 820 g
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
- 13" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 3000 x 2000 (3K2K)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 450 cd/m²
- Colour Gamut
- 100% sRGB
- Corning Gorilla glass 4, Low Power Ultra Slim bent
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - VGA
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, 3 multi-array microphone
- Audio Features
- Noise-cancellation technology, Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, touchpad with gesture support, gesture function
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Intel Wireless Display (WiDi), dual stream (2x2)
- IEEE 802.11i, Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- HSPA+, LTE
- Controller
- HP lt4220
- Service Provider
Navigation
- Receiver
- GPS/A-GPS
- Technology
- 4-cell lithium polymer
- Installed Qty
- 1
- Capacity
- 50 Wh
- Run Time
- Up to 10.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- 2 x USB-C 3.1 (supports Thunderbolt) , USB-C 3.1 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Systems Software Manager (free download), HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalog, HP JumpStart, HP Workwise, HP Noise Cancellation, HP JetAdvantage, HP PhoneWise, HP Manageability & Integration Kit Gen2, Ivanti Management Suite
- Integrated Options
- Security
- HP Automatic Drive Lock, HP DriveLock, HP Fingerprint Sensor, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- Keyboard, USB-C power adapter, WACOM AES pen
- Low halogen
- Localization
- 820 g
- Dimensions (WxDxH) / Weight Details
- 30 cm x 23.15 cm x 1.33 cm / 1.17 kg - tablet with keyboard , 30 cm x 23.15 cm x 0.79 cm / 820 g - tablet
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE | In Stock | £35.26 |
HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook | In Stock | £41.06 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £123.80 |
Other bundles (7)
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
