HP Elite x2 1013 G3 Intel Core i3-7100U 4GB 128GB SSD 13" Touch Windows 10 Professional 64-bit
Quicklinx: F700WS00 Mfr#: 2TS86EA#ABU
  • Core i3
  • IEEE 802.11n
Win the day with full PC performance and unleash creativity with the freedom of a tablet. Powerful processors handle your professional apps while tablet mobility lets you keep working on the go. The Elite x2 1013 delivers on the promise of the detachable device.
  • Creativity without compromise
    Powerfully handle your professional apps with this incredibly thin and light 13-inch detachable business PC. Get a pure tablet experience with the optional HP Rechargeable Active Pen.
  • Designed to bring people together
    Huddle with the team or connect across continents. Collaboration is built into the DNA of the HP Elite x2 1013, equipped with premium audio, high-resolution cameras, and a world facing mic.
  • Keep wandering eyes at bay
    Help protect your PC from outside threats with a comprehensive suite of security tools. Keep prying eyes away from your creations on the HP Elite x2 1013 with the optional HP Sure View Gen2 integrated privacy screen and the HP Sure View app in tablet mode.
HP Elite x2 1013 G3 - 13" - Core i3 8130U - 4 GB RAM - 128 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (8th Gen) 8130U / 2.2 GHz (3.4 GHz) / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
13" LED backlight touchscreen 3000 x 2000 / 3K2K
Graphics
Intel UHD Graphics 620
Input Device
Keyboard, ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10.5 hours
Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor, hall sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Dimensions (WxDxH) - tablet
30 cm x 23.15 cm x 0.79 cm
820 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
128 GB SSD M.2 2280 PCIe
Display
13" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
3000 x 2000 (3K2K)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
450 cd/m²
Colour Gamut
100% sRGB
Corning Gorilla glass 4, Low Power Ultra Slim bent
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - VGA
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, 3 multi-array microphone
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Layout
Volume control, touchpad with gesture support, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Intel Wireless Display (WiDi), dual stream (2x2)
IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
50 Wh
Run Time
Up to 10.5 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
2 x USB-C 3.1 (supports Thunderbolt) , USB-C 3.1 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Systems Software Manager (free download), HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalog, HP JumpStart, HP Workwise, HP Noise Cancellation, HP JetAdvantage, HP PhoneWise, HP Manageability & Integration Kit Gen2, Ivanti Management Suite
Integrated Options
Security
HP Automatic Drive Lock, HP DriveLock, HP Fingerprint Sensor, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Keyboard, USB-C power adapter, WACOM AES pen
Low halogen
Localization
820 g
Dimensions (WxDxH) / Weight Details
30 cm x 23.15 cm x 1.33 cm / 1.17 kg - tablet with keyboard , 30 cm x 23.15 cm x 0.79 cm / 820 g - tablet
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
F700 HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
F700 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £123.80
Other bundles (6)
F700 HP USB-C To VGA Adapter In Stock £22.68
F700 HP USB Travel Mouse In Stock £9.99
F700 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
F700 HP Premium Wireless Mouse In Stock £38.00
F700 HP USB-C to DisplayPort Adapter In Stock £23.53
F700 HP USB-C to HDMI 2.0 Adapter In Stock £47.06
