Your basket is empty
HP Elite x2 1012 G1 Intel Core M5-6Y54 8GB 256GB SSD 12" Windows 10 Professional 64-bit
Quicklinx: BTXWWS00 Mfr#: L5H19EA#ABU
Display Size: 12in
Processor Model: M5-6Y54
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB, 8GB
Hard Drive Capacity: 256GB
  • IEEE 802.11n
£1,063.14 ex VAT
£1,275.76 inc VAT
HP Elite x2 1012 Tablet with Detachable Keyboard
Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
Mobility and style without compromise
Strikingly thin and elegant, the Elite x2 1012 is a 2 in 1 for the mobile workforce and executives who want no compromises when it comes to enterprise-class power, durability, optional LTE connectivity4 and productivity on the go, in a stylish design.
Designed for IT, loved by users
Stunning IT friendly design. Elite x2 1012 incorporates Elite global enterprise-class security and manageability features, enterprise-class durability, on-site serviceability,2 global sku availability and support across 180 countries.
Accessories built for how you work
At your desk or on the road, meet the specific needs of your work day with the included HP Active Pen with App Launch that uses Wacom technology. Accessorize to boost your efficiency. Add optional enterprise docking solutions3 and advanced keyboards.
Featuring
The tools you need to succeed
Start, work, and transition between modes easily with Window 10 Pro.
A great mobile productivity keyboard
Superb typing experience, with high performance keyboards for productivity on the go with the HP Elite x2 1012 keyboard options.
Capture spontaneous ideas
Create with the precision and accuracy of industry preferred Wacom technology in the HP Active Pen with App Launch.
Performance to get the job done
The quiet fanless design and 10 hours of battery life8 lets you work, surf, and connect with colleagues.
Speedy transfers
Charge devices, transfer data quickly, and connect to 4k devices with the USB-C™ port with Thunderbolt™ technology.
Connect and collaborate in style
Conduct virtual meetings with Audio by Bang & Olufsen, HP Noise Reduction Software and front/back camera.
Powerful defenses for data and devices
Help keep sensitive information safe with the latest with Windows 10 Pro1 and HP Client Security5 technology solutions.
Management made easy
Reduce management time thanks to the 2-in-1 design and HP Client Management Solutions9 and optional Intel® vPro.™
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that’s available 24x7, covering multiple brands, devices and operating systems.
HP Elite x2 1012 G1 - 12" - Core m5 6Y54 - 8 GB RAM - 256 GB SSD - UK - with HP Elite x2 1012 G1 Travel Keyboard, HP Active Pen
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz (2.7 GHz) / 4 MB Cache
8 GB LPDDR3
Storage
256 GB - M.2 SSD
Display
12" LED backlight touchscreen 1920 x 1280 / WUXGA+
Graphics
Intel HD Graphics 515
Input Device
Keyboard, ClickPad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10.25 hours
Ambient light sensor, proximity sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Dimensions (WxDxH) - tablet
30 cm x 21.35 cm x 0.805 cm
820 g
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Bundled with
Operating System
Windows 10 Pro 64-bit Edition - English
Bundled with
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
Max RAM Supported
8 GB
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2) SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
340 cd/m²
Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement, rear camera with flash
Sound
Stereo speakers, two microphones
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard, ClickPad
Backlight
Keyboard Layout
Volume control, touchpad with gesture support, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Intel Wireless Display (WiDi)
IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
Max Supported Qty
1
40 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
45 Watt, 1.4 A
Connections & Expansion
USB-C/Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , LAN (on supplied cable) , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
Integrated Options
Dockable
Security
Security lock slot (cable lock sold separately), HP DuraKeys, HP SpareKey, built-in leg stand, Accelerometer, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
Power adapter, keyboard
Localization
820 g
Dimensions (WxDxH) / Weight Details
30 cm x 21.35 cm x 13.45 cm / 1.205 kg - tablet with keyboard , 30 cm x 21.93 cm x 0.61 cm / 385 g - keyboard dock
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Software applications
HP Elite x2 1012 G1 Intel Core M5-6Y54 8GB 256GB SSD 12 Bundle deal on HP Elite x2 1012 G1 Intel Core M5-6Y54 8GB 256GB SSD 12" Windows 10 Professional 64-bit
£1,218.13
saving £8.33
Display Size: 12in
Optical Storage: None
Graphics: Intel HD Graphics 515
Hard Drive Type: SSD
Touchscreen: Yes
Brand: HP
Price Range Ex VAT: 1000 - 1500
