Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
Mobility and style without compromise
Strikingly thin and elegant, the Elite x2 1012 is a 2 in 1 for the mobile workforce and executives who want no compromises when it comes to enterprise-class power, durability, optional LTE connectivity and productivity on the go, in a stylish design. -
Designed for IT, loved by users
Stunning IT friendly design. Elite x2 1012 incorporates Elite global enterprise-class security and manageability features, enterprise-class durability, on-site serviceability, global sku availability and support across 180 countries. -
Accessories built for how you work
At your desk or on the road, meet the specific needs of your work day with the included HP Active Pen with App Launch that uses Wacom technology. Accessorize to boost your efficiency. Add optional enterprise docking solutions and advanced keyboards.
- HP Elite x2 1012 G1 - 12" - Core m5 6Y54 - 8 GB RAM - 256 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz (2.7 GHz) / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 12" LED backlight touchscreen 1920 x 1280 / WUXGA+
- Graphics
- Intel HD Graphics 515
- Input Device
- Digital pen
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- HP Mobile Connect
- Battery
- 4-cell - up to 10.25 hours
- Ambient light sensor, proximity sensor, hall sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 30 cm x 21.35 cm x 0.805 cm
- 840 g
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD - (M.2) SATA 6Gb/s
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1280 (WUXGA+)
- Widescreen
- Image Aspect Ratio
- 3:2
- Image Brightness
- 340 cd/m²
- Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 1080p Full HD movie recording, low light enhancement, rear camera with flash
- Sound
- Stereo speakers, two microphones
- Audio Features
- Noise-cancellation technology, Bang & Olufsen Audio
Input
- Digital pen
- Volume control
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Intel Wireless Display (WiDi)
- IEEE 802.11i, Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- GPRS, EDGE, LTE, DC-HSPA+, CDMA 2000 1X EV-DO Rev. B
- Controller
- HP lt4120 - M.2 Card
- Max Transfer Rate
- 100 Mbps
- Service Provider
- HP Mobile Connect
Navigation
- Receiver
- A-GPS/GPS/GLONASS
- Technology
- 4-cell lithium polymer
- Installed Qty
- 1
- Max Supported Qty
- 1
- Capacity
- 40 Wh
- Run Time
- Up to 10.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 1.4 A
Connections & Expansion
- Slots
- 1 x Micro-SIM card (0 free)
- USB-C/Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
- Integrated Options
- Dockable
- Security
- HP DuraKeys, HP SpareKey, built-in leg stand, Accelerometer, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- Power adapter, HP Active Pen
- Localization
- 840 g
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
