HP Elite x2 1012 G1 Intel Core M5-6Y54 8GB 256GB SSD 12" Windows 10 Professional 64-bit
Quicklinx: BTXTWS00 Mfr#: L5H03EA#ABU
Display Size: 12in
Processor Model: M5-6Y54
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • IEEE 802.11n
£1,204.11 ex VAT
£1,444.93 inc VAT
Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's a tested-tough 2 in 1 with precision-crafted keyboards, and a thin and light powerhouse designed to the exacting standards of the enterprise.
  • Mobility and style without compromise
    Strikingly thin and elegant, the Elite x2 1012 is a 2 in 1 for the mobile workforce and executives who want no compromises when it comes to enterprise-class power, durability, optional LTE connectivity and productivity on the go, in a stylish design.
  • Designed for IT, loved by users
    Stunning IT friendly design. Elite x2 1012 incorporates Elite global enterprise-class security and manageability features, enterprise-class durability, on-site serviceability, global sku availability and support across 180 countries.
  • Accessories built for how you work
    At your desk or on the road, meet the specific needs of your work day with the included HP Active Pen with App Launch that uses Wacom technology. Accessorize to boost your efficiency. Add optional enterprise docking solutions and advanced keyboards.
HP Elite x2 1012 G1 - 12" - Core m5 6Y54 - 8 GB RAM - 256 GB SSD
Tablet - no keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz (2.7 GHz) / 4 MB Cache /
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
12" LED backlight touchscreen 1920 x 1280 / WUXGA+
Graphics
Intel HD Graphics 515
Input Device
Digital pen
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10.25 hours
Ambient light sensor, proximity sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
30 cm x 21.35 cm x 0.805 cm
840 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
Max RAM Supported
8 GB
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2) SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
340 cd/m²
Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement, rear camera with flash
Sound
Stereo speakers, two microphones
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Digital pen
Volume control
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Intel Wireless Display (WiDi)
IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
Max Supported Qty
1
40 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
45 Watt, 1.4 A
Connections & Expansion
USB-C/Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
Integrated Options
Dockable
Security
HP DuraKeys, HP SpareKey, built-in leg stand, Accelerometer, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter, HP Active Pen
Localization
840 g
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Software applications
HP Elite x2 1012 G1 Intel Core M5-6Y54 8GB 256GB SSD 12 Bundle deal on HP Elite x2 1012 G1 Intel Core M5-6Y54 8GB 256GB SSD 12" Windows 10 Professional 64-bit
£1,303.28
Display Size: 12in
Optical Storage: None
Graphics: Intel HD Graphics 515
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
