HP Elite x2 1012 G1 Intel Core M3-6Y30 4GB 128GB SSD 12" Windows 10 Professional 64-bit
Quicklinx: BTXKWS00 Mfr#: L5H17ET#ABU
  • IEEE 802.11n
Enjoy the full benefits of a 2-in-1 for less when you invest in the HP Elite x2 1012. Lightweight and thin, this laptop packs a lot of power into its compact size, making it your ideal companion when you’re on the move.
It comes with a 12-inch display and powerful Intel HD Graphics 515 for crystal clear visuals. Its touchscreen capability means you can use it with or without the keyboard, which is especially handy for users on the daily commute.
At just 820g, this HP Elitebook neatly fits into your bag without weighing it down.
Its speedy 6th generation Intel Core processor gives you solid and reliable performance while the 128GB SSD storage ensures swift load-up times, enhancing productivity.
With up to 10.25 hours’ battery life, you can carry on working without worrying about losing power. Should you wish to use it in the office, the HP Elite 1012 is dockable so you can access all of your important documents and view them on a larger desktop screen which is great when giving a presentation that you’ve worked on away from the office.
Take advantage of the Trusted Platform Module security chip to stay in control of your sensitive data.
  • The tools you need to succeed
    Start, work, and transition between modes easily with Windows 10 Pro.
  • A great mobile productivity keyboard
    Superb typing experience, with high performance keyboards for productivity on the go with the HP Elite x2 1012 keyboard options.
  • Capture spontaneous ideas
    Create with the precision and accuracy of industry preferred Wacom technology in the HP Active Pen with App Launch.
  • Performance to get the job done
    The quiet fanless design and 10 hours of battery life lets you work, surf, and connect with colleagues.
  • Speedy transfers
    Charge devices, transfer data quickly, and connect to 4k devices with the USB-C port with Thunderbolt technology.
  • Connect and collaborate in style
    Conduct virtual meetings with Audio by Bang & Olufsen, HP Noise Reduction Software and front/back camera.
HP Elite x2 1012 G1 - 12" - Intel Core m3 - 6Y30 - 4 GB RAM - 128 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core m3 (6th Gen) - 6Y30 / 900 MHz, up to 2.2 GHz / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
12" LED backlight touchscreen 1920 x 1280 / WUXGA+
Graphics
Input Device
Keyboard, digital pen, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell - up to 10.25 hours
Ambient light sensor, proximity sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Dimensions (WxDxH) - tablet
30 cm x 21.35 cm x 0.8 cm
820 g
Environmental Standards
- ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core m3 (6th Gen) 6Y30 / 900 MHz
Max Turbo Speed
2.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
340 cd/m²
Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement, rear camera with flash
Sound
Stereo speakers, two microphones
Audio Features
Output: noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Volume control, touchpad with gesture support, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
Max Supported Qty
1
40 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
45 Watt 1.4 A
Connections & Expansion
Interfaces Details
USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software
Integrated Options
Dockable
Security
HP DuraKeys, HP SpareKey, built-in leg stand, Accelerometer, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter, keyboard, HP Active Pen, HP Elite x2 1012 G1 Travel Keyboard
Localization
820 g
Dimensions (WxDxH) / Weight Details
30 cm x 21.35 cm x 1.345 cm / 1.205 kg - tablet with keyboard , 30 cm x 21.93 cm x 0.61 cm / 385 g - keyboard dock
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
