HP Elite x2 1011 G1 Intel Core M-5Y51 4GB 128GB 11.6" Windows 8.1 Professional 64-bit
Quicklinx: BBDMWS00 Mfr#: L5G45EA#ABU
  • Windows 8.1 Pro 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
Enjoy the benefits of both tablet and Ultrabook when you invest in the HP Elite 1011. This handy portable device comes with all the management and security features you need for working on the move.
Thanks to its touchscreen you can use the HP Elite as a tablet for easy computing on the move and simply connect to the keyboard dock if you need to type documents.
Weighing just 1.54kg, it’s the ideal portable companion for when you need to work on the go. Enjoy speedy internet access with the 802.11n technology, helping you to work efficiently and smartly.
The 11.6-inch display offers HD resolution while the powerful Intel graphics and high definition audio ensures you get the most out of the integrated webcam. With low light enhancement, you’ll also benefit from Full HD video recording.
Connect your HP Ultrabook to a docking station when you’re in the office to allow you to continue working on the same files. Need a bigger screen? Simply connect it up to your desktop monitor, and stay in control of your sensitive documents with the SmartCard reader security feature.
  • The tools you need to succeed
    Make edits with the Wacom pen and enjoy stability from the reflex hinge on the optional keyboard.
  • Built-in durability
    Enjoy a premium durable design engineered to undergo MIL-STD 810G testing and HP's Total Test Process.
  • Connect and collaborate
    Organize virtual meetings with optional Qualcomm GOBI 4G LTE WWAN and two cameras.
  • More convenience, less to manage
    Reduce management time thanks to the 2-in-1 design and HP Client Management Solutions and Intel vPro.
  • In it for the long haul
    Benefit from the stability of a long lifecycle and global series support.
  • Cloud-based IT management made simple
    Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
HP Elite x2 1011 G1 - 11.6" - Intel Core M - 5Y10c - 4 GB RAM - 128 GB SSD - UK
Tablet - with keyboard dock
Operating System
Win 8.1 Pro 64-bit - English
Intel Core M 5Y10c / 800 MHz, up to 2 GHz / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 5300
Input Device
Keyboard, ForcePad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) - tablet with keyboard
29.8 cm x 20.61 cm x 2.08 cm
1.54 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Operating System
Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
11.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement
Sound
Stereo speakers, stereo microphone
Codec
Realtek ALC3228
High Definition Audio, DTS Studio Sound
Input
Keyboard, ForcePad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Lithium polymer
Installed Qty
2
Max Supported Qty
2
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
DisplayPort (on keyboard dock) , 4 x USB 3.0 (on keyboard dock) , Dock (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Skype, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, Netflix, Foxit PhantomPDF Express, Windows Defender, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, Box.net 50GB storage, HP Wireless Hotspot, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Roaming Alert, HP Driver Packs, LANDesk Management Suite (free download)
Dockable
Security
HP Disk Sanitizer, HP SpareKey, HP File Sanitizer, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Measured Boot, Power On Authentication, Pre-Boot Security
Stylus, power adapter
Localization
1.54 kg
Dimensions (WxDxH) / Weight Details
29.8 cm x 19.27 cm x 1.07 cm / 780 g - tablet , 29.8 cm x 20.46 cm x 0.97 cm / 780 g - keyboard dock
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
