Enjoy the benefits of both tablet and Ultrabook when you invest in the HP Elite 1011. This handy portable device comes with all the management and security features you need for working on the move.
Thanks to its touchscreen you can use the HP Elite as a tablet for easy computing on the move and simply connect to the keyboard dock if you need to type documents.
Weighing just 1.54kg, it’s the ideal portable companion for when you need to work on the go. Enjoy speedy internet access with the 802.11n technology, helping you to work efficiently and smartly.
The 11.6-inch display offers HD resolution while the powerful Intel graphics and high definition audio ensures you get the most out of the integrated webcam. With low light enhancement, you’ll also benefit from Full HD video recording.
Connect your HP Ultrabook to a docking station when you’re in the office to allow you to continue working on the same files. Need a bigger screen? Simply connect it up to your desktop monitor, and stay in control of your sensitive documents with the SmartCard reader security feature.
The tools you need to succeed
Make edits with the Wacom pen and enjoy stability from the reflex hinge on the optional keyboard. -
Built-in durability
Enjoy a premium durable design engineered to undergo MIL-STD 810G testing and HP's Total Test Process. -
Connect and collaborate
Organize virtual meetings with optional Qualcomm GOBI 4G LTE WWAN and two cameras. -
More convenience, less to manage
Reduce management time thanks to the 2-in-1 design and HP Client Management Solutions and Intel vPro. -
In it for the long haul
Benefit from the stability of a long lifecycle and global series support. -
Cloud-based IT management made simple
Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
- HP Elite x2 1011 G1 - 11.6" - Intel Core M - 5Y10c - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 8.1 Pro 64-bit - English
- Processor
- Intel Core M 5Y10c / 800 MHz, up to 2 GHz / 4 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5300
- Input Device
- Keyboard, ForcePad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Dimensions (WxDxH) - tablet with keyboard
- 29.8 cm x 20.61 cm x 2.08 cm
- 1.54 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 1080p Full HD movie recording, low light enhancement
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC3228
- High Definition Audio, DTS Studio Sound
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Technology
- Lithium polymer
- Installed Qty
- 2
- Max Supported Qty
- 2
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- DisplayPort (on keyboard dock) , 4 x USB 3.0 (on keyboard dock) , Dock (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Skype, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, Netflix, Foxit PhantomPDF Express, Windows Defender, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, Box.net 50GB storage, HP Wireless Hotspot, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Roaming Alert, HP Driver Packs, LANDesk Management Suite (free download)
- Dockable
- Security
- HP Disk Sanitizer, HP SpareKey, HP File Sanitizer, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Measured Boot, Power On Authentication, Pre-Boot Security
- Included Accessories
- Stylus, power adapter
- Localization
- 1.54 kg
- Dimensions (WxDxH) / Weight Details
- 29.8 cm x 19.27 cm x 1.07 cm / 780 g - tablet , 29.8 cm x 20.46 cm x 0.97 cm / 780 g - keyboard dock
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
