Create a remarkably powerful and streamlined workspace with expansive device, display, and network connectivity plus simultaneous charging with the HP Elite Thunderbolt 3 90W Dock.
Have a lot to attach? No problem! Link up to 10 devices at once through ports that include Thunderbolt™ 3 (which also supports Display Port™ 1.2 and USB 3.1 Gen 2), four USB 3.0, RJ-45, VGA, combo audio, and two additional Display Port™ ports.
Rapidly replenish your HP EliteBook’s power after a demanding day with an impressive charging station that passes power directly through a Thunderbolt™ 3 power cable.
Proudly display this sleek and efficient solution in the office, or tuck it away and clean up your workspace for good. Either way, no more cables and no more clutter to worry about.
Take multi-tasking to the extreme with support for two UHD/4K displays that can be ready to broadcast every color and detail of your projects through a superfast bandwidth connection as soon as you plug into to the dock.
Compatible with HP ProBook x360 11 G1 EE; HP Elite X2 1012 G2; HP EliteBook x360; HP Elite x2 1012 G1 Tablet; HP EliteBook Folio G1
Amplify your notebook
Have a lot to attach? No problem! Link up to 10 devices at once through ports that include Thunderbolt 3 (which also supports Display Port 1.2 and USB 3.1 Gen 2), four USB 3.0, RJ-45, VGA, combo audio, and two additional Display Port ports. -
Charge and connect
Rapidly replenish your HP EliteBook's power after a demanding day with an impressive charging station that passes power directly through a Thunderbolt 3 power cable. -
Tidy up
Proudly display this sleek and efficient solution in the office, or tuck it away and clean up your workspace for good. Either way, no more cables and no more clutter to worry about. -
Expand your view
- HP Elite 90W Thunderbolt 3 Dock - docking station - Thunderbolt 3 - VGA, Mini DP - 10Mb LAN
- Product Type
- Docking station
- Docking Interface
- Thunderbolt 3
- Video Interfaces
- VGA, Mini DP
- 23 cm x 5.7 cm x 1.75 cm
- 220 g
- Networking
- Ethernet
- Power
- Power adapter AC 120/230 V (50/60 Hz) 90 Watt Power Provided
- Designed For
- Elite x2; EliteBook 1040 G4 Notebook, 830 G5 Notebook, 840 G5 Notebook, 850 G5 Notebook; EliteBook Folio G1; EliteBook x360; ZBook 14u G5 Mobile Workstation, 15u G5 Mobile Workstation; ZBook x2
- Product Type
- Docking station
- 23 cm
- 5.7 cm
- 1.75 cm
- 220 g
- Data Link Protocol
- Ethernet
- 1 x PoweredUSB 3.0 , 3 x SuperSpeed USB 3.0 , 1 x USB-C , 2 x display / video - DisplayPort , 1 x display / video - VGA , 1 x Thunderbolt 3 - Mini DisplayPort , 1 x audio - headphones/microphone , 1 x network - RJ-45
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 90 Watt
- 0 °C
- 35 °C
- Designed For
- HP Elite x2 1012 G1, 1012 G2, 1013 G3 , HP EliteBook 1040 G4 Notebook, 830 G5 Notebook, 840 G5 Notebook, 850 G5 Notebook , HP EliteBook Folio G1 , HP EliteBook x360 1012 G2 Notebook, 1020 G2 Notebook, 1030 G2 Notebook, 1030 G3 Notebook, 1040 G5 Notebook , HP ZBook 14u G5 Mobile Workstation, 15u G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
