Transform your multi-display viewing experience into one ultra-thin curved screen that conserves your desk space and budget with the HP E344c 34-inch Curved Monitor. Get comfortable with adjustable positioning and conveniently connect to your devices and PC with a range of ports.
One massive screen, no visual distractions
View all of your content at one time on the 34" diagonal curved screen with WQHD resolution and a 21:9 aspect ratio-the same screen space of multiple displays, without the bezel breaks. -
Convenient connectivity to everything you use
Connect your current and legacy devices right at the display with DisplayPort , HDMI, a four-port USB hub with powered USB for device charging, USB-C , and USB-C with DisplayPort Alt Mode. -
Lean in and find your sweet spot
Get room to move around on your desk with the simplicity of a single ultra-thin curved screen and only one set of cables and connectors. Raise or lower the screen height up to 150 mm and tilt and swivel for the best view.
- HP E344c - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class G
- Energy Consumption per Year
- 77 kWh
- Power Consumption (On mode)
- 32.2 W
- Curved Screen
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- WQHD 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.231 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 3000:1 / 5000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Gamut
- 99.5% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Sparkling black
- 80.92 cm x 22 cm x 54.2 cm
- 11 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, VCCI, BSMI, TUV S, CB, CCC, PSB, FCC, KCC, Energy-using Products (EuP) Lot 6, WEEE, ICES, cTUVus, MEPS, E-Standby, CEC, KC, CECP, EAC, CEL Grade 1, ISC, SEPA, BIS, low halogen, DisplayPort 1.2, Energy-using Products (EuP) Lot 5, AUS/NZ, Mercury-free
- Display Type
- Energy Class
- Class G
- 77 kWh
- Diagonal Size
- 34"
- Curved Screen
- Yes (1800R)
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.231 mm
- Pixel Per Inch
- 109.6
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Gamut
- 99.5% sRGB
- Response Time
- Vertical Refresh Rate
- 30 - 76 Hz
- Horizontal Refresh Rate
- 30 - 94 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, arsenic-free glass, 3-sided micro-edge, 8-bit Colour Depth
- Sparkling black
- 80.92 cm x 22 cm x 54.2 cm - with stand
- 11 kg
- DisplayPort (HDCP) , HDMI (HDCP) , USB-C 3.2 Gen 1 upstream/DisplayPort Alt Mode , USB-C 3.2 Gen 1 downstream (power up to 22.5W) , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand base
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB-A to USB-B cable - 1.8 m , 1 x USB-C cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 32.2 W
- Power Consumption SDR (On mode)
- 32.2 kWh/1000h
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 80.92 cm - depth: 22 cm - height: 54.2 cm - weight: 11 kg , Without stand - width: 80.92 cm - depth: 10.095 cm - height: 36.568 cm - weight: 7 kg
- Shipping Width
- 91 cm
- Shipping Depth
- 29 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 16.11 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
