Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E22 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Experience simple, convenient connectivity
Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub. -
Find your comfort zone
Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors. -
Responsibly made
Energy efficiency is built into every ENERGY STAR certified, EPEAT 2019 registered, and low halogen display. We go one step further with 100% recyclable packaging that's easily accepted by recycling facilities. -
Take your PC off the desk
Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket. -
Personalize and help protect your monitor
Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC. -
Complete the picture
Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
- HP E22 G4 - E-Series - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class D
- Power Consumption (On mode)
- 13 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.87 cm x 20.7 cm x 48.06 cm
- 5.3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CEL, EAC, CEL Grade 1, ISC, low halogen, DisplayPort 1.2, ICE, HP GSE, Australian-New Zealand MEPS, Vietnam MEPS
- 3-year warranty
- Bundled Services
- HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth, HP Eye Ease, 72% NTSC colour gamut
- Black
- 48.87 cm x 20.7 cm x 48.06 cm - with stand
- 5.3 kg
- DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13 W
- Power Consumption SDR (On mode)
- 13 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center
- Dimensions & Weight Details
- With stand - width: 48.87 cm - depth: 20.7 cm - height: 48.06 cm - weight: 5.3 kg , Without stand - width: 48.87 cm - depth: 4.7 cm - height: 29.46 cm - weight: 2.88 kg
- Shipping Width
- 56.5 cm
- Shipping Depth
- 21.1 cm
- Shipping Height
- 35 cm
- Shipping Weight
- 7.7 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - parts and labour - 3 years
- Bundled Services
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
