Get hardware security for your notebook and another device like a display or dock with the HP Dual Head Master Cable Lock, which locks both devices to the lock and then a third fixed surface.
Pair and lock
Loop one end of the 7 ft (2.13 m) vinyl-coated, galvanized steel cable around a secure object, attach one lock to your notebook and the other to a dock, printer or display. Insert the master key into the lock and turn clockwise 90 degrees to lock. -
Room to move
The cable head swivels 360 degrees to help you position the cable as needed before you lock. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP Dual Head Master Cable Lock - security cable lock
- Product Type
- Security cable lock
- Package Content
- 2 x keys
- Length
- 2.13 m
- 140 g
- 360° head rotation
- 1-year warranty
- Product Type
- Package Content
- 2 x keys
- Length
- 2.13 m
- Diameter
- 0.45 cm
- 140 g
- Limited warranty: - 1 year
