HP DT Mini DVD-Writer ODD Module - SuperSpeed USB 3.0
Quicklinx: CKJYWS00 Mfr#: K9Q83AA
Drive Type: DVD writer
Enclosure Type: External
Interface: SuperSpeed USB 3.0
Colour: Jack black
Type: Disk drive
£74.55 ex VAT
£89.46 inc VAT
Add a DVD Writer to your HP Desktop Mini PC with HP Desktop Mini DVD Writer ODD Module.
Easy assembly
Slide and hook the Module to the PC with the included screws, connect with the included USB 2.0 cable, and use the integrated VESA mount to place the Module wherever you need it.
Make it secure
Lock the Module to your HP Desktop Mini or a desk or table with the optional HP Ultra-Slim Cable Lock.
World-class support
Rest easy with a one-year limited warranty.
  • Easy assembly
  • Make it secure
  • World-class support
HP DVD±RW (±R DL) / DVD-RAM drive - SuperSpeed USB 3.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
Jack black
SuperSpeed USB 3.0
2.28 cm x 17.46 cm x 1.77 cm
712 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Media Load Type
Tray
HP 260 G1, 260 G2, 260 G3, 260 G4; EliteDesk 705 G1, 705 G3 (mini desktop), 705 G5, 800 G1, 800 G3 (mini desktop); EliteOne 800 G6; ProDesk 400 G1, 400 G5 (mini desktop), 405 G4, 600 G1, 600 G2 (mini desktop), 600 G3 (mini desktop), 600 G4
Jack black
SuperSpeed USB 3.0
2.28 cm
17.46 cm
1.77 cm
712 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Supported Media Types
CD-R, CD-RW, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
160 ms (DVD), 140 ms (CD)
1 x USB 3.0 - 9 pin USB Type B
1 x SuperSpeed USB cable - external
5 °C
50 °C
10 - 80% (non-condensing)
HP 260 G1, 260 G2, 260 G3, 260 G4 , HP EliteDesk 705 G1, 705 G3 (mini desktop), 705 G5, 800 G1, 800 G3 (mini desktop) , HP EliteOne 800 G6 , HP ProDesk 400 G1, 400 G5 (mini desktop), 405 G4, 600 G1, 600 G2 (mini desktop), 600 G3 (mini desktop), 600 G4
Colour: Jack black
Type: Disk drive
Brand: HP
