HP DreamColour Z32X LED 31.5" Monitor 3840x2160 8MS
Quicklinx: C7YWWS00 Mfr#: M2D46AT#ABU
Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
  • Admire every detail
    Explore your creativity with 8 million pixels and 4K resolution-four times that of a traditional Full HD display-on an extra-large 80,01 cm (31.5") diagonal screen.
  • Color as only HP DreamColor can do it
    Get exceptional, consistent 10-bit color precision and out-of-the-box, color-calibrated sRGB, BT709, and Adobe RGB coverage from HP DreamColor technology. Use the HP DreamColor Calibration Kit or your choice of tool for precise color adjustments.
  • Boost your productivity
    Connect to an array of your everyday devices right at the display with HDMI, mDP, DP, MHL, and a USB 3.0 hub with a fast-charging port. View up to four simultaneous feeds with picture-in-picture or picture-by-picture.
HP DreamColor Z32x Professional - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class C
Energy Consumption per Year
116 kWh
Power Consumption (On mode)
80 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
73.71 cm x 24.55 cm x 61.38 cm
10.8 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, ISC, SEPA
3-year warranty
Display Type
Energy Class
Class C
116 kWh
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL), Mercury free, arsenic-free glass
73.71 cm x 24.55 cm x 61.38 cm - with stand
10.8 kg
MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Security lock slot (cable lock sold separately), 1 USB 3.0 fast charging port
1 x DisplayPort cable , 1 x Mini DisplayPort cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
80 W
Power Consumption (Typical)
80 Watt
Power Consumption Stand by
0.45 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
