Boost your creativity with the HP DreamColor Z27x G2 Studio Display. Designed for color professionals, this 27" diagonal Quad HD display has breakthrough HP DreamColor Technology, an expansive color gamut, built-in colorimeter, and workflow management tools.
High Performance Custom Panel
Experience a broad range of vividly accurate colors from 98% Adobe RGB and 99% DCI P3 coverage. Work with inky blacks, rich shadow detail, and a 1500:1 contrast ratio. Get superb off-axis viewing from a high-performance IPS panel. -
Built-in Colorimeter
Stay on schedule by setting automated color calibration to run after hours. Align the built-in colorimeter with your own reference instrument for studio-wide color stability. -
Quad HD
Bring your designs and images to life in stunning detail on a 27" diagonal screen with Quad HD 2560 ×1440 resolution and a 16:9 aspect ratio. -
Integrated KVM Switch
Easily alternate between different computers with the built-in KVM switch and a keyboard shortcut. -
Remote Manageability
Remotely manage a single display or an entire fleet with integrated tools that let you modify settings, pull calibration histories or push out new configurations over a network connection. -
Customizable Color Presets
Choose from eight factory-calibrated color presets or configure your own.
- HP DreamColor Z27x G2 Studio Display - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Energy Consumption per Year
- 64 kWh
- Power Consumption (On mode)
- 44 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 10.2 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% BT.709, 100% sRGB, 98% DCI-P3, 99% Adobe RGB
- Input Connectors
- 2xHDMI, 2xDisplayPort, USB-C
- Built-in Ethernet
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.21 cm x 24.8 cm x 57.28 cm
- 12.1 kg
- Localisation
- English / United Kingdom
- Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, E-Standby, KC, EPA, CEL Grade 3
- 3-year warranty
- Display Type
- Energy Class
- Class G
- 64 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 27 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6504K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Picture by picture, HDCP, Low Blue Light Mode, Flicker Free technology, Mercury free, Factory Calibration, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture
- Black
- 64.21 cm x 24.8 cm x 57.28 cm - with stand
- 12.1 kg
- 2 x HDMI (HDCP) , 2 x DisplayPort (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (HDCP) , USB (Type A) , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 downstream (fast charging) , Audio line-out , Management (RJ-45)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 201 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x USB-C cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-C to USB-A cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
- Backlight Life
- 30,000 hour(s)
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 44 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Windows 10
- Dimensions & Weight Details
- Without stand - width: 64.21 cm - depth: 8.25 cm - height: 38.21 cm - weight: 7.4 kg , With stand - width: 64.21 cm - depth: 24.8 cm - height: 57.28 cm - weight: 12.1 kg
- Shipping Width
- 78.4 cm
- Shipping Depth
- 38 cm
- Shipping Height
- 49.4 cm
- Shipping Weight
- 16 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.83 |
