HP DreamColour Z27x G2 27" 2560x1440 10.2ms 2xHDMI 2xDisplayPort USB-C LED Monitor
Quicklinx: F53VWS00 Mfr#: 2NJ08AT#ABU
Boost your creativity with the HP DreamColor Z27x G2 Studio Display. Designed for color professionals, this 27" diagonal Quad HD display has breakthrough HP DreamColor Technology, an expansive color gamut, built-in colorimeter, and workflow management tools.
  • High Performance Custom Panel
    Experience a broad range of vividly accurate colors from 98% Adobe RGB and 99% DCI P3 coverage. Work with inky blacks, rich shadow detail, and a 1500:1 contrast ratio. Get superb off-axis viewing from a high-performance IPS panel.
  • Built-in Colorimeter
    Stay on schedule by setting automated color calibration to run after hours. Align the built-in colorimeter with your own reference instrument for studio-wide color stability.
  • Quad HD
    Bring your designs and images to life in stunning detail on a 27" diagonal screen with Quad HD 2560 ×1440 resolution and a 16:9 aspect ratio.
  • Integrated KVM Switch
    Easily alternate between different computers with the built-in KVM switch and a keyboard shortcut.
  • Remote Manageability
    Remotely manage a single display or an entire fleet with integrated tools that let you modify settings, pull calibration histories or push out new configurations over a network connection.
  • Customizable Color Presets
    Choose from eight factory-calibrated color presets or configure your own.
HP DreamColor Z27x G2 Studio Display - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
1500:1
Response Time
10.2 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% BT.709, 100% sRGB, 98% DCI-P3, 99% Adobe RGB
Input Connectors
2xHDMI, 2xDisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
64.21 cm x 24.8 cm x 57.28 cm
12.1 kg
English / United Kingdom
Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, E-Standby, KC, EPA, CEL Grade 3
3-year warranty
Display Type
Energy Class
Class G
64 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
250 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
27 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6504K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Picture by picture, HDCP, Low Blue Light Mode, Flicker Free technology, Mercury free, Factory Calibration, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture
64.21 cm x 24.8 cm x 57.28 cm - with stand
12.1 kg
2 x HDMI (HDCP) , 2 x DisplayPort (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (HDCP) , USB (Type A) , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 downstream (fast charging) , Audio line-out , Management (RJ-45)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
201 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x USB-C cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-C to USB-A cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
Backlight Life
30,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
44 W
32.1 kWh/1000h
Power Consumption (Typical)
65 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Windows 10
Dimensions & Weight Details
Without stand - width: 64.21 cm - depth: 8.25 cm - height: 38.21 cm - weight: 7.4 kg , With stand - width: 64.21 cm - depth: 24.8 cm - height: 57.28 cm - weight: 12.1 kg
Shipping Width
78.4 cm
Shipping Depth
38 cm
Shipping Height
49.4 cm
Shipping Weight
16 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
F53V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
F53V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
F53V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
F53V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.83
