Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable 61 cm (24") diagonal HP DreamColor Z24x G2 Display.
Stay focused
Minimize distractions onscreen with flicker-free image presentation and on the bezel with HP Night Vision UI's auto-fade button backlights that relight with a touch. -
Make room
Streamline your workspace with the optional HP PC Mounting Bracket for Monitors, which lets you mount powerful machines like the HP Z2 Mini Workstation directly behind the display.
- HP DreamColor Z24x G2 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 43 kWh
- Power Consumption (On mode)
- 29 W
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 100% sRGB, 97% DCI-P3, 99% Adobe RGB
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.94 cm x 23.8 cm x 52.5 cm
- 6.98 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, low halogen
- 5-year warranty
- Display Type
- Energy Class
- Class B
- 43 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6504K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Picture in picture, HDCP, integrated cable management
- Black
- 6.98 kg
- DVI-D (Single-Link) , DisplayPort , HDMI , DisplayPort output , Audio line-out , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 151 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 29 W
- Power Consumption (Typical)
- 54.18 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities, HP DreamColor Calibration
- OS Required
- Microsoft Windows 7 / 8 / 10
- Dimensions & Weight Details
- With stand - width: 55.94 cm - depth: 23.8 cm - height: 52.5 cm - weight: 6.98 kg , Without stand - width: 55.94 cm - depth: 6.65 cm - height: 36.5 cm - weight: 4.73 kg
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
