HP DreamColour Z24 G2 24" 1920x1200 6ms HDMI DVI-D DisplayPort LED Monitor
Quicklinx: DZRKWS00 Mfr#: 1JR59AT#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 6ms
Interfaces: DVI, DisplayPort, HDMI
£614.83 ex VAT
£737.79 inc VAT
Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable 61 cm (24") diagonal HP DreamColor Z24x G2 Display.
  • Stay focused
    Minimize distractions onscreen with flicker-free image presentation and on the bezel with HP Night Vision UI's auto-fade button backlights that relight with a touch.
  • Make room
    Streamline your workspace with the optional HP PC Mounting Bracket for Monitors, which lets you mount powerful machines like the HP Z2 Mini Workstation directly behind the display.
HP DreamColor Z24x G2 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
29 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 97% DCI-P3, 99% Adobe RGB
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
55.94 cm x 23.8 cm x 52.5 cm
6.98 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, low halogen
5-year warranty
Display Type
Energy Class
Class B
43 kWh
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6504K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Picture in picture, HDCP, integrated cable management
6.98 kg
DVI-D (Single-Link) , DisplayPort , HDMI , DisplayPort output , Audio line-out , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
151 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
29 W
Power Consumption (Typical)
54.18 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP DreamColor Calibration
Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
With stand - width: 55.94 cm - depth: 23.8 cm - height: 52.5 cm - weight: 6.98 kg , Without stand - width: 55.94 cm - depth: 6.65 cm - height: 36.5 cm - weight: 4.73 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 6ms
Interfaces: DVI
Interfaces: DisplayPort
Interfaces: HDMI
Brand: HP
Price Range Ex VAT: £500 - £750
