HP DreamColour Z24 G2 24" 1920x1200 6ms HDMI DVI-D DisplayPort LED Monitor
Quicklinx: DZRKWS00 Mfr#: 1JR59AT#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 6ms
Interfaces: DisplayPort, DVI, HDMI
More than 50 in stock
£612.41 ex VAT
£734.89 inc VAT
Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable 61 cm (24") diagonal HP DreamColor Z24x G2 Display.
  • Bring your vision to life with HP DreamColor technology
    Get a wide array of digital cinema-class color gamuts, including 100% coverage of sRGB and BT.709 and 99% of Adobe RGB, and great on-and off-axis views from the wide-angle HP DreamColor panel.
  • Accurate color calibration to meet your exact needs
    Experience color accuracy between each of your HP DreamColor displays. Calibrate any of the four color space presets-sRGB, Adobe RGB, BT.709, and User-or create your own custom color space with HP DreamColor Calibration Software.
  • Smooth color transitions
    Achieve minimal banding across your project's color gradients with a bit depth of 10 bits that produces 1,024 gray levels per channel and up to a billion colors.
HP DreamColor Z24x G2 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
29 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
55.94 cm x 23.8 cm x 52.5 cm
6.98 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, low halogen
5-year warranty
Display Type
Energy Class
Class B
43 kWh
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6504K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Picture in picture, HDCP, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, integrated cable management, 97% DCI-P3, 100% Rec 709 colour gamut
6.98 kg
DVI-D (Single-Link) , DisplayPort , HDMI , DisplayPort output , Audio line-out , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
151 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
29 W
Power Consumption (Typical)
54.18 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP DreamColor Calibration
Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
With stand - width: 55.94 cm - depth: 23.8 cm - height: 52.5 cm - weight: 6.98 kg , Without stand - width: 55.94 cm - depth: 6.65 cm - height: 36.5 cm - weight: 4.73 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 6ms
Interfaces: DVI
Interfaces: HDMI
Brand: HP
Price Range Ex VAT: £500 - £750
Stock Status: In stock
