Designed for the world's elite color professionals, the award-winning HP DreamColor Technology brings the industry's boldest visions to life. Captivate with Cinema 4K resolution, an expansive color gamut for remarkably vivid colors, integrated colorimeter and custom-tailored management tools.
And the award goes to…
The display that walked the red carpet. The HP DreamColor Technology won the 2015 Scientific and Engineering Award from the Academy of Motion Picture Arts and Sciences. Experience theater-quality color from HP's most precise display yet. -
More time creating
Maintain accurate color with a pop-up sensor that calibrates on demand or on a regular schedule. No longer wonder if your color is correct-it just is. -
Designed by pros
HP worked with leading visual effects and animation studios to create customized solutions for the optimal design process. Speed projects to completion with True 2K, onscreen markers and keyboard-based input switching between your devices.
- HP DreamColor Z31x Studio Display - LED monitor - 4K - 31.1"
- LED-backlit LCD monitor - 31.1"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 17:9
- Native Resolution
- 4K 4096 x 2160 at 60 Hz
- Pixel Pitch
- 0.1704 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 10 ms (On/Off)
- Colour Support
- 1.074 billion colours (10-bit)
- Input Connectors
- 2xHDMI, 2xDisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 73.8 cm x 24.8 cm x 56.6 cm
- 15 kg
- Localisation
- English / United Kingdom
- Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, ICES, S Mark, MEPS, E-Standby, KC, CECP, CEL, Energy-using Products (EuP) Lot 5, SmartWay
- 5-year warranty
- Display Type
- Diagonal Size
- 31.1"
- Viewable Size
- 31.1"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 17:9
- Native Resolution
- Pixel Pitch
- 0.1704 mm
- Pixel Per Inch
- 149
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Response Time
- 10 ms (On/Off)
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Picture in picture, picture by picture, Zero Bright Dot, sRGB colour management, HDCP, 10-bit gamma, 100% Adobe RGB colour gamut, 100% sRGB colour gamut, integrated cable management, Low Blue Light Mode, Flicker Free technology, Mercury free, Color Calibration, arsenic-free glass, 99% DCI-P3, 100% BT.709 colour gamut, 80% BT.2020 colour gamut, remote calibration, script calibration
- Black
- 73.8 cm x 24.8 cm x 56.6 cm - with stand
- 15 kg
- 2 x DisplayPort , 2 x HDMI , USB-C , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Height Adjustment
- 144 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), fast charging
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x power cable - 1.9 m , 1 x USB-C cable - 1.8 m , 1 x USB-C to USB 3.0 type A cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 120 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 73.8 cm - depth: 24.8 cm - height: 56.6 cm - weight: 15 kg , Without stand - width: 73.8 cm - depth: 8.26 cm - height: 41.41 cm - weight: 9.9 kg
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80%
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£2,082.50
