HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor
SEE PRODUCT PAGE FOR OFFERS AND PROMOTIONS
Limited Time Offer
Quicklinx: F53WWS00 Mfr#: Z4Y82A4#ABU
Diagonal Size: 31.1in
Max Resolution: 4096 x 2160
Response Time: 10ms
Interfaces: DisplayPort, HDMI, USB-C
£2,017.36 ex VAT
£2,420.83 inc VAT
Designed for the world's elite color professionals, the award-winning HP DreamColor Technology brings the industry's boldest visions to life. Captivate with Cinema 4K resolution, an expansive color gamut for remarkably vivid colors, integrated colorimeter and custom-tailored management tools.
  • And the award goes to…
    The display that walked the red carpet. The HP DreamColor Technology won the 2015 Scientific and Engineering Award from the Academy of Motion Picture Arts and Sciences. Experience theater-quality color from HP's most precise display yet.
  • More time creating
    Maintain accurate color with a pop-up sensor that calibrates on demand or on a regular schedule. No longer wonder if your color is correct-it just is.
  • Designed by pros
    HP worked with leading visual effects and animation studios to create customized solutions for the optimal design process. Speed projects to completion with True 2K, onscreen markers and keyboard-based input switching between your devices.
HP DreamColor Z31x Studio Display - LED monitor - 4K - 31.1"
LED-backlit LCD monitor - 31.1"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
17:9
Native Resolution
4K 4096 x 2160 at 60 Hz
Pixel Pitch
0.1704 mm
Brightness
250 cd/m²
Contrast Ratio
1500:1
Response Time
10 ms (On/Off)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
2xHDMI, 2xDisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
73.8 cm x 24.8 cm x 56.6 cm
15 kg
English / United Kingdom
Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, ICES, S Mark, MEPS, E-Standby, KC, CECP, CEL, Energy-using Products (EuP) Lot 5, SmartWay
5-year warranty
Display Type
Diagonal Size
31.1"
Viewable Size
31.1"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
17:9
Native Resolution
Pixel Pitch
0.1704 mm
Pixel Per Inch
149
Brightness
250 cd/m²
Contrast Ratio
1500:1
Colour Support
Response Time
10 ms (On/Off)
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Picture in picture, picture by picture, Zero Bright Dot, sRGB colour management, HDCP, 10-bit gamma, 100% Adobe RGB colour gamut, 100% sRGB colour gamut, integrated cable management, Low Blue Light Mode, Flicker Free technology, Mercury free, Colour Calibration, arsenic-free glass, 99% DCI-P3, 100% BT.709 colour gamut, 80% BT.2020 colour gamut, remote calibration, script calibration
73.8 cm x 24.8 cm x 56.6 cm - with stand
15 kg
2 x DisplayPort , 2 x HDMI , USB-C , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Height Adjustment
144 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), fast charging
Stand
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x power cable - 1.9 m , 1 x USB-C cable - 1.8 m , 1 x USB-C to USB 3.0 type A cable - 1.8 m
Backlight Life
30,000 hours
120 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 73.8 cm - depth: 24.8 cm - height: 56.6 cm - weight: 15 kg , Without stand - width: 73.8 cm - depth: 8.26 cm - height: 41.41 cm - weight: 9.9 kg
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80%
Response Time: 10ms
Interfaces: HDMI
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 1500+
