Work in brilliant, trusted color and bring your ideas to life with the HP DreamColor Z27x Studio Display, featuring HP's unrivaled integrated calibration engine, 4K input support, and 10-bit color that drives up to 1.07 billion onscreen colors.
Astonishing performance for the color professional
Consistently deliver rich, accurate colors and ultra-deep blacks with HP's custom-engineered 68,6 cm (27') diagonal DreamColor panel. Get massive 2560 x 1440 resolution and crisp, clear presentation from 1000:1 contrast ratio and high brightness. -
The power tool for your color workflow
Experience up to 1.07 billion colors with 1,024 tones per channel as the HP DreamColor Engine 2 powers through your 4K content with 10-bit color accuracy and easily handles today's most demanding professional workflows. -
Color customization at your fingertips
Create your own color space with just one-touch with the integrated calibration engine. Enjoy seamless compatibility with a range of professional colorimetric devices, including the optional HP DreamColor Calibration Solution.
- HP DreamColor Z27x Professional - LED monitor - 27"
- Display Type
- Energy Class
- Class C
- Energy Consumption per Year
- 86 kWh
- Power Consumption (On mode)
- 59 W
- Diagonal Size
- 27"
- Viewable Size
- 27"
- Built-in Devices
- USB Hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 1.07 billion colours
- Response Time
- 7 ms (grey-to-grey)
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 24 - 113 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
- HDCP, 100% Adobe RGB colour gamut, 100% sRGB colour gamut
- Black
- 64.1 cm x 24.24 cm x 42.04 cm - with stand
- 8.8 kg
Mechanical
- Height, pivot (rotation), swivel, tilt
- Tilt Angle
- -5/+20
- Swivel Angle
- 45
- Height Adjustment
- 120 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
- Backlight Life
- 50,000 hours
- Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CEL, EPA, ISC, CEL Grade 2
- Localisation
- English / United Kingdom
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 65 Watt
- Power Consumption Stand by
- 0.47 Watt
- Power Consumption Sleep
- 0.43 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- Without stand - width: 64.1 cm - depth: 6.55 cm - height: 37.92 cm - weight: 6.4 kg
Environmental Standards
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£961.45
