Brand
HP DreamColor Z27x 27" 2560x1440 7ms HDMI DisplayPort USB LED Monitor
Quicklinx: BKYDWS00 Mfr#: D7R00A4#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 7ms
Speakers: None
Interfaces: HDMI, DisplayPort
£862.28 ex VAT
£1,034.73 inc VAT
Work in brilliant, trusted color and bring your ideas to life with the HP DreamColor Z27x Studio Display, featuring HP's unrivaled integrated calibration engine, 4K input support, and 10-bit color that drives up to 1.07 billion onscreen colors.
  • Astonishing performance for the color professional
    Consistently deliver rich, accurate colors and ultra-deep blacks with HP's custom-engineered 68,6 cm (27') diagonal DreamColor panel. Get massive 2560 x 1440 resolution and crisp, clear presentation from 1000:1 contrast ratio and high brightness.
  • The power tool for your color workflow
    Experience up to 1.07 billion colors with 1,024 tones per channel as the HP DreamColor Engine 2 powers through your 4K content with 10-bit color accuracy and easily handles today's most demanding professional workflows.
  • Color customization at your fingertips
    Create your own color space with just one-touch with the integrated calibration engine. Enjoy seamless compatibility with a range of professional colorimetric devices, including the optional HP DreamColor Calibration Solution.
HP DreamColor Z27x Professional - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
86 kWh
Power Consumption (On mode)
59 W
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, 2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
64.1 cm x 24.24 cm x 42.04 cm
8.8 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CEL, EPA, ISC, CEL Grade 2
5-year warranty
Display Type
Energy Class
Class C
86 kWh
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
24 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
HDCP, 100% Adobe RGB colour gamut, 100% sRGB colour gamut
64.1 cm x 24.24 cm x 42.04 cm - with stand
8.8 kg
Mechanical
Tilt Angle
-5/+20
Swivel Angle
45
Height Adjustment
120 mm
1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Backlight Life
50,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
59 W
65 Watt
Power Consumption (Typical)
65 Watt
Power Consumption Stand by
0.47 Watt
Power Consumption Sleep
0.43 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 64.1 cm - depth: 6.55 cm - height: 37.92 cm - weight: 6.4 kg
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Warranties (1)
BKYD HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
Other bundles (1)
BKYD HP PC Mounting Bracket For Monitors In Stock £48.94
Diagonal Size: 27in
Response Time: 7ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: HP
Price Range Ex VAT: £750 - £1000
