HP DreamColor Z24x 24" 1920x1200 6ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: BKYFWS00 Mfr#: E9Q82A4#ABU
Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable HP DreamColor Z24x Display.
  • Turn on your creativity with a premium display
    Bring your dreams to life with a 61 cm (24') diagonal DreamColor panel that produces up to a billion colors from a massive color gamut covering 99% of Adobe RGB.
  • The power tool for your color workflow
    Experience push-button color space selection as the HP DreamColor Engine 2 powers through your content with a bit depth of 10 bit (8+2 FRC).
  • Easy color customization at your fingertips
    Use the optional HP DreamColor Calibration Solution to recalibrate any preset or create your own color space.
HP DreamColor Z24x Professional - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB Hub
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Pivot (rotation), swivel, tilt
Screen Coating
Anti-glare
Voltage
55.94 cm x 23.8 cm x 52.5 cm
6.98 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV GS, VCCI, C-Tick, NOM, WHQL, CCC, PSB, FCC, RoHS, WEEE, S Mark, CECP, EAC, CEL Grade 1
3-year warranty
Display Type
Diagonal Size
24"
Built-in Devices
USB Hub
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP
6.98 kg
DVI , DisplayPort , HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
1 x USB cable , 1 x display cable , 1 x DVI adapter , 1 x power cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
58 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
