Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable HP DreamColor Z24x Display.
Turn on your creativity with a premium display
Bring your dreams to life with a 61 cm (24') diagonal DreamColor panel that produces up to a billion colors from a massive color gamut covering 99% of Adobe RGB. -
The power tool for your color workflow
Experience push-button color space selection as the HP DreamColor Engine 2 powers through your content with a bit depth of 10 bit (8+2 FRC). -
Easy color customization at your fingertips
Use the optional HP DreamColor Calibration Solution to recalibrate any preset or create your own color space.
- HP DreamColor Z24x Professional - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB Hub
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 55.94 cm x 23.8 cm x 52.5 cm
- 6.98 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, TUV GS, VCCI, C-Tick, NOM, WHQL, CCC, PSB, FCC, RoHS, WEEE, S Mark, CECP, EAC, CEL Grade 1
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- USB Hub
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP
- 6.98 kg
- DVI , DisplayPort , HDMI
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Cables Included
- 1 x USB cable , 1 x display cable , 1 x DVI adapter , 1 x power cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 58 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80%
