Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable HP DreamColor Z24x Display.
Turn on your creativity with a premium display
Bring your dreams to life with a 61 cm (24') diagonal DreamColor panel that produces up to a billion colors from a massive color gamut covering 99% of Adobe RGB. -
The power tool for your color workflow
Experience push-button color space selection as the HP DreamColor Engine 2 powers through your content with a bit depth of 10 bit (8+2 FRC). -
Easy color customization at your fingertips
Use the optional HP DreamColor Calibration Solution to recalibrate any preset or create your own color space.
- HP DreamColor Z24x Professional - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class C
- Energy Consumption per Year
- 69 kWh
- Power Consumption (On mode)
- 47 W
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey), 20 ms (typical)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB, 99% Adobe RGB
- Input Connectors
- HDMI, DVI-D, 2xDisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.94 cm x 23.8 cm x 52.5 cm
- 6.98 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, UL, TUV GS, VCCI, C-Tick, NOM, WHQL, CCC, PSB, FCC, RoHS, WEEE, S Mark, EAC, CEL Grade 1, TUV KC
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 69 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
- DreamColor
- Black
- 55.94 cm x 23.8 cm x 52.5 cm - with stand
- 6.98 kg
- DVI-D (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , HDMI (HDCP) , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 47 W
- Power Consumption (Typical)
- 58 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 55.94 cm - depth: 6.65 cm - height: 36.5 cm - weight: 4.73 kg , With stand - width: 55.94 cm - depth: 23.8 cm - height: 52.5 cm - weight: 6.98 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
