HP DreamColor Z24x 24" 1920x1200 12ms DVI-D HDMI DisplayPort USB LED Monitor
Quicklinx: 9G21WS00 Mfr#: E9Q82AT#ABU
in stock
£384.28 ex VAT
£461.13 inc VAT
Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable HP DreamColor Z24x Display.
  • Turn on your creativity with a premium display
    Bring your dreams to life with a 61 cm (24') diagonal DreamColor panel that produces up to a billion colors from a massive color gamut covering 99% of Adobe RGB.
  • The power tool for your color workflow
    Experience push-button color space selection as the HP DreamColor Engine 2 powers through your content with a bit depth of 10 bit (8+2 FRC).
  • Easy color customization at your fingertips
    Use the optional HP DreamColor Calibration Solution to recalibrate any preset or create your own color space.
HP DreamColor Z24x Professional - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
69 kWh
Power Consumption (On mode)
47 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey), 20 ms (typical)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB, 99% Adobe RGB
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
55.94 cm x 23.8 cm x 52.5 cm
6.98 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, UL, TUV GS, VCCI, C-Tick, NOM, WHQL, CCC, PSB, FCC, RoHS, WEEE, S Mark, EAC, CEL Grade 1, TUV KC
3-year warranty
Display Type
Energy Class
Class C
69 kWh
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
DreamColor
55.94 cm x 23.8 cm x 52.5 cm - with stand
6.98 kg
DVI-D (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , HDMI (HDCP) , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
Stand
1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
47 W
Power Consumption (Typical)
58 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 55.94 cm - depth: 6.65 cm - height: 36.5 cm - weight: 4.73 kg , With stand - width: 55.94 cm - depth: 23.8 cm - height: 52.5 cm - weight: 6.98 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
