HP Digital Sender Flow 8500 FN1 Document Capture Workstation
Quicklinx: 9HDMWS00 Mfr#: L2719A#B19
Move your business beyond paper-intensive processes. Integrate with existing networked manageability and security solutions. Improve workflows by creating a virtually unlimited number of scan profiles and reliably handle up to 5,000 pages a day.
  • Enjoy forward-looking, high-speed productivity
    Reclaim your time. Scan up to 60 pages per minute and 120 images per minute – even do two-sided scans.Easily manage jobs on the 20.3cm (8-inch) HP Easy Select touchscreen colour control panel with pullout keyboard.Do more with data using multiple scan-to options – folders, FTP sites, email, USB drives, SharePoint and more.Expand capture capabilities and seamlessly integrate solutions through the hardware integration pocket.
  • Outstanding content management and easy collaboration
    Get high-volume performance, time and again – scan up to 5,000 pages daily with minimal user intervention.Bring data to life with built-in OCR capabilities, then save scans in a variety of file formats.Get fast results from single-pass scanning and HP EveryPage. Automatically remove blank pages.Manage big jobs with the 100-sheet automatic document feeder. Reliably handle scan jobs with mixed originals.
  • Get the digital sending security your business demands
    Scan and send documents without worry – the HP High-Performance Secure Hard Disk helps keep sensitive data safe.Maintain security throughout the document lifecycle by enabling a variety of authentication options.Easily manage who can scan and where files can be saved, using advanced security features – including IPSec.Enable easy sharing of sensitive data when you create encrypted, password-protected PDFs.
  • Seamless management from the very start
    Proactively and centrally manage the device with the rest of your imaging and printing environment.Expand workteam capabilities within your print environment, using a rich array of easy-to-integrate solutions.Redefine workflows and help reduce distribution costs, using optional HP Capture and Route software.Create advanced, custom workflows across a variety of devices, using optional HP Digital Sending Software.
HP Digital Sender Flow 8500 fn1 Document Capture Workstation - document scanner - desktop - USB 2.0, Gigabit LAN
Document scanner - desktop
Interface Type
Scanning Sensor Type
Flatbed: CCD / ADF: CIS
Light Source
LED
Additional Functions
Email, fax, scan to network share
Max Supported Document Size
A4 (210 x 297 mm)
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 45 ppm (colour)
Max Document Size
210 mm x 297 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card, labels, photo
Document Feeder Type
Manual, automatic
Document Storage Capacity
100 sheets
Duty Cycle
5000 scans per day
52.07 cm x 53.34 cm x 30.81 cm
20.18 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
5000 scans per day
Scanner Features
Built-in High Performance Secure Hard Disk, 8" touch screen TFT display, Ultrasonic Multi Feed Detection, built-in keyboard, Hardware Integration Pocket (HIP)
Media Handling
Max Document Size
210 mm x 297 mm
Manual, automatic
100 sheets
Interfaces Details
Gigabit LAN , USB 2.0 - Type A
CSA, C-Tick, BSMI, CISPR 22 Class A, GOST, CISPR 24, EN55024, EN55022 Class A, CB, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, IEC 60950-1 Second Edition, EN 61000-3-2:2006, EN 60950-1:2006, EN 61000-3-3:1995+A1:2001+A2:2005, CAN/CSA-C22.2 No. 60950-1
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
70 Watt (24 Watt)
Software Included
I.R.I.S. OCR
52.07 cm
53.34 cm
30.81 cm
20.18 kg
Shipping Width
63 cm
Shipping Depth
60.1 cm
Shipping Height
42.8 cm
Shipping Weight
23.5 kg
10 °C
35 °C
15 - 80% (non-condensing)
