Move your business beyond paper-intensive processes. Integrate with existing networked manageability and security solutions. Improve workflows by creating a virtually unlimited number of scan profiles and reliably handle up to 5,000 pages a day.
- HP Digital Sender Flow 8500 fn1 Document Capture Workstation - document scanner - desktop - USB 2.0, Gigabit LAN
- Document scanner - desktop
- Interface Type
- Scan Element Type
- Flatbed: CCD / ADF: CIS
- Light Source
- LED
- Additional Functions
- Email, fax, scan to network share
- Max Supported Document Size
- A4 (210 x 297 mm)
- Localisation
- English, German, French, Italian, Spanish / Europe
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 60 ppm (mono) / 45 ppm (colour)
- Max Document Size
- 210 mm x 297 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, card scanner, plastic card, labels, photo
- Document Feeder Type
- Manual, automatic
- Document Storage Capacity
- 100 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- 52.07 cm x 53.34 cm x 30.81 cm
- 20.18 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- A4 (210 x 297 mm)
- Localisation
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Scan Element Type
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 60 ppm
- Max Document Scan Speed Colour
- 45 ppm
- Duty Cycle
- Scanner Features
- Built-in High Performance Secure Hard Disk, 8" touch screen TFT display, Ultrasonic Multi Feed Detection, built-in keyboard, Hardware Integration Pocket (HIP)
Media Handling
- Max Document Size
- 210 mm x 297 mm
- Manual, automatic
- 100 sheets
- Gigabit LAN , USB 2.0 - Type A
- CSA, C-Tick, BSMI, CISPR 22 Class A, GOST, CISPR 24, EN55024, EN55022 Class A, CB, CCC, EMC, FCC, UL 60950-1 Second Edition, KCC, CAN/CSA C22.2 No. 60950-1, IEC 60950-1 Second Edition, EN 61000-3-2:2006, EN 60950-1:2006, EN 61000-3-3:1995+A1:2001+A2:2005
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 70 Watt (24 Watt)
- Software Included
- I.R.I.S. OCR
- 52.07 cm
- 53.34 cm
- 30.81 cm
- 20.18 kg
- Shipping Width
- 63 cm
- Shipping Depth
- 60.1 cm
- Shipping Height
- 42.8 cm
- Shipping Weight
- 23.5 kg
- 10 °C
- 35 °C
- 15 - 80% (non-condensing)
