All the features. All the value. Print, scan, and copy, and get a 35 page auto feeder. Count on simple setup[1] and worry-free wireless.[2] Choose HP+ at setup to receive 9 months of Instant Ink [3] and an extended (up to 2 years) HP warranty.[4]
Added extras so you can do more Work fast and hands-free – the 35 page auto feeder helps you complete scan and copy jobs quickly. Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.[1] Get better range and faster, more reliable connections using dual-band Wi-Fi® with self-reset.[2] Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.[3]
Simple setup. Simple printing.
Get started fast with simple setup that guides you through each step, using HP Smart app.[1] Easily handle tasks and get a lot from one device – print, scan, and copy. Get quick and easy printing directly at the control panel. This printer is made from recycled printers and other electronics – more than 20% by weight of plastic.
Never run out of ink with Instant Ink[4]
Never run out of ink.[4] Convenient ink cartridge replacements and smart delivery included. Save up to 70% with Instant Ink.[5] Enroll to get ink, delivery and recycling starting at £0.99 a month. Peace of mind with plan flexibility to change or cancel anytime at no cost.[6] Help us put plastic back into printers with prepaid recycling service included.[7]
With HP+, get HP’s simplest printing solution and more value with exclusive use of Original HP Ink. Opt in to HP+ during printer setup to get 9 months of Instant Ink[10] and an extra year of HP warranty (up to 2 years).[4] A cloud-connected HP+ printer is smarter - it keeps itself up to date and ready to print.[8] Never run out of ink and save up to 70% with Instant Ink. 9 months included with HP+.[3,6,7] Print and scan from the palm of your hand. Enjoy advanced productivity features for 2 years with HP+.[1] HP+ requires an HP account, ongoing internet connection, and use of Original HP ink cartridges.
Hands-free. Auto-fed
Work fast and hands-free – the 35 page auto-feeder helps you complete scan and copy jobs quickly. -
Seamless setup
Get started fast with simple setup that guides you through each step, using HP Smart app. -
Your reliable connection
Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset. -
Print, scan, and copy from your phone
With HP Smart app, print everyday documents, get high-quality scanning and sharing, and easily make copies – all from your phone. -
HP+, the cloud-connected, smart printing system
An HP+ printer is ready when you are, more secure and productive than ever. -
Tackle the essentials
Get versatile performance and print, scan, and copy.
- HP Deskjet 4130e All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 100 - 300 pages
- Max Copying Speed
- Up to 6 ppm (mono) / up to 3 ppm (colour)
- Max Copying Resolution
- Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
- Max Printing Speed
- Up to 8.5 ppm (mono) / up to 5.5 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 14.4 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper
- Standard Media Capacity
- 60 sheets
- Max Media Capacity
- 60 sheets
- Output Trays Capacity
- 25 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), Bluetooth 4.2
- AirPrint Enabled
- Office Machine Features
- Print from mobile devices, scan to PDF, HP+ enabled
- Power
- AC 120/230 V (50/60Hz)
- 42.8 cm x 33.2 cm x 20 cm
- 4.82 kg
- Enclosure Colour
- Indigo
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- Ink-jet - colour
- 1000 pages
- 100 - 300 pages
- Display Features
- LCD display
- Interface
- AirPrint Enabled
- Enclosure Colour
- Indigo
- Localisation
- Standard Memory
- 84 MB
- Max Supported Memory
- 84 MB
Copying
- Max Copying Speed
- Maximum Copies
- 9
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 328 nozzles (black), 588 nozzles (colour)
- Ink Cartridge Configuration
- 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI, PCLm, URF
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 19 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 14.4 Kbps
- PC Faxing
Fax Machine Features
- Fax forwarding, automatic redialing, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Supported Original Sizes
- 216 x 297 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 145 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm)
- 60 sheets
- 60 sheets
- 25 sheets
- ADF - 35 sheets , Input tray - 60 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 145 lbs , Output tray - 25 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 8.5 ppm (A4) - B/W (ISO) , Printing: up to 5.5 ppm (A4) - colour (ISO) , Copying: up to 6 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) , Scanning: up to 2.5 ppm (A4) - B/W (200 dpi) , Scanning: up to 2.5 ppm (A4) - colour (200 dpi) , Scanning: up to 2.5 ppm (Letter A) - B/W (200 dpi) , Scanning: up to 2.5 ppm (Letter A) - colour (200 dpi)
- 1 x USB 2.0 - 4 pin USB Type B
- Software Included
- Drivers & Utilities, HP Smart App
- Voltage Required
- Power Consumption Sleep
- 1.1 Watt
- Consumables Included
- 1 x ink cartridge (black) - HP 67 , 1 x ink cartridge (yellow/cyan/magenta) - HP 67
- FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6 Class B, EN 301 489-17 V3.1.1 (2017), CISPR 35, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- EPEAT Compliant
- EPEAT Silver
- Limited warranty - 1 year
- 42.8 cm
- 33.2 cm
- 20 cm
- 4.82 kg
- Shipping Width
- 47.5 cm
- Shipping Depth
- 24.2 cm
- Shipping Height
- 40.5 cm
- Shipping Weight
- 6.19 kg
- Sound Emission
- 56 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
