Get the compact printing power and wireless independence you need to print, scan, and copy from virtually any mobile device. The world's smallest all-in-one printer is an Instant Ink ready printer that fits and looks good virtually anywhere.
You don't need to worry about the DeskJet 3720 taking up too much space as it's the most compact all-in-one printer ever. It fits seamlessly into your space letting you easily print tickets, copy photos, scan documents, and much more.
Delivering vibrant colours, the DeskJet 3720 is ideal for printing lab-quality photos from your smartphone, tablet or PC.
Wireless connectivity
There's no need for trailing wires - effortlessly print from any room in the house thanks to Apple AirPrint and the free HP Printer Remote app for managing tasks from your devices.
With optional quiet mode you can print from any room without causing disruptions, making it even easier for the whole family to use.
HP Instant Ink
The DeskJet 3720 includes a three-month free trial of HP's Instant Ink, a quicker and more cost efficient way of purchasing ink.
Save up to 70% on ink with HP Instant Ink
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty. -
The tiny all-in-one that packs a punch
Save space and get the power you need with the world's smallest all-in-one printer.HP Scroll Scan helps you easily handle most scan jobs or use your mobile phone to scan and send to print any object.Any room, any spot – this ultracompact all-in-one is designed to fit where you need it.Show your style with a sleek design and a variety of head-turning hues. -
Fits your budget, fits your needs
Wirelessly print, scan, and copy what you need quickly and easily with this affordable all-in-one.Print 2.5x as many pages with optional Original HP high-yield ink cartridges.Easily recycle your Original HP cartridges at no charge through HP Planet Partners. -
Quickly print right from your mobile device
The easiest way to print documents, photos, and more from your Apple, Android, and Windows devices.Connect your smartphone or tablet directly to your printer, and easily print without a network.Get connected quickly and start printing fast with easy setup from your smartphone or tablet.Scan any object on the go with the HP All-in-One Printer Remote mobile app for your smartphone or tablet.
- HP Deskjet 3720 All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- English / United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 50 - 200 pages
- Max Copying Speed
- Up to 5.5 ppm (mono) / up to 3 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 8 ppm (mono) / up to 5.5 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 600 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper
- Standard Media Capacity
- 60 sheets
- Output Trays Capacity
- 25 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- HP Auto Wireless Connect, Mobile Printing, HP Auto-On/Auto-Off Technology
- Power
- AC 120/230 V (50/60Hz)
- 40.3 cm x 17.7 cm x 14.1 cm
- 2.33 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 1000 pages
- 50 - 200 pages
- Display Features
- 7 segment LCD display with icons
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
Copying
- Max Copying Speed
- Maximum Copies
- 9
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 18 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 dpi
- Interpolated Resolution
- 1200 dpi
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International B5 (176 x 250 mm), A4 (210 x 297 mm)
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- 60 sheets
- 25 sheets
- Input tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 19 ppm (A4) - B/W draft , Printing: up to 15 ppm (A4) - colour draft , Printing: up to 19 ppm (Letter A) - B/W draft , Printing: up to 15 ppm (Letter A) - colour draft , Printing: up to 8 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Printing: 65 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 5.5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.8, Windows 8, Windows 8.1, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 10
- Software Included
- Drivers & Utilities
- Voltage Required
- Power Consumption Standby
- 2.2 Watt
- Power Consumption Sleep
- 0.69 Watt
- Included Accessories
- USB cable
- Consumables Included
- 1 x ink cartridge (black) - up to 120 pages - HP 65 , 1 x ink cartridge (yellow/cyan/magenta) - up to 100 pages - HP 65
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - 1 year
- 40.3 cm
- 17.7 cm
- 14.1 cm
- 2.33 kg
- Shipping Weight
- 3.34 kg
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
