Product
HP DeskJet 3720 AIO Printer
Quicklinx: CRD6WS00 Mfr#: J9V93B#BEV
Get the compact printing power and wireless independence you need to print, scan, and copy from virtually any mobile device. The world's smallest all-in-one printer is an Instant Ink ready printer that fits and looks good virtually anywhere.
You don't need to worry about the DeskJet 3720 taking up too much space as it's the most compact all-in-one printer ever. It fits seamlessly into your space letting you easily print tickets, copy photos, scan documents, and much more.
Delivering vibrant colours, the DeskJet 3720 is ideal for printing lab-quality photos from your smartphone, tablet or PC.
Wireless connectivity
There's no need for trailing wires - effortlessly print from any room in the house thanks to Apple AirPrint and the free HP Printer Remote app for managing tasks from your devices.
With optional quiet mode you can print from any room without causing disruptions, making it even easier for the whole family to use.
HP Instant Ink
The DeskJet 3720 includes a three-month free trial of HP's Instant Ink, a quicker and more cost efficient way of purchasing ink.
  • Save up to 70% on ink with HP Instant Ink
    Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty.
  • The tiny all-in-one that packs a punch
    Save space and get the power you need with the world's smallest all-in-one printer.HP Scroll Scan helps you easily handle most scan jobs or use your mobile phone to scan and send to print any object.Any room, any spot – this ultracompact all-in-one is designed to fit where you need it.Show your style with a sleek design and a variety of head-turning hues.
  • Fits your budget, fits your needs
    Wirelessly print, scan, and copy what you need quickly and easily with this affordable all-in-one.Print 2.5x as many pages with optional Original HP high-yield ink cartridges.Easily recycle your Original HP cartridges at no charge through HP Planet Partners.
  • Quickly print right from your mobile device
    The easiest way to print documents, photos, and more from your Apple, Android, and Windows devices.Connect your smartphone or tablet directly to your printer, and easily print without a network.Get connected quickly and start printing fast with easy setup from your smartphone or tablet.Scan any object on the go with the HP All-in-One Printer Remote mobile app for your smartphone or tablet.
HP Deskjet 3720 All-in-One - multifunction printer - colour
Multifunction printer
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 200 pages
Max Copying Speed
Up to 4 ppm (mono) / up to 2.5 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 19 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
600 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Auto Wireless Connect, Mobile Printing, HP Auto-On/Auto-Off Technology
AC 120/230 V (50/60Hz)
40.3 cm x 17.7 cm x 14.1 cm
2.33 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Printing Technology
Ink-jet - colour
1000 pages
50 - 200 pages
Display Features
7 segment LCD display with icons
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
First Print Out Time B/W
15 sec
First Print Out Time Colour
18 sec
Scanning
Scan Element
CIS
Optical Resolution
600 dpi
Interpolated Resolution
1200 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International B5 (176 x 250 mm), A4 (210 x 297 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
60 sheets
25 sheets
Input tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 8 ppm (A4) - B/W (ISO) , Printing: up to 5.5 ppm (A4) - colour (ISO) , Copying: up to 4 ppm (A4) - B/W (ISO) , Copying: up to 2.5 ppm (A4) - colour (ISO) , Printing: up to 19 ppm - B/W draft , Printing: up to 15 ppm - colour draft
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.8, Windows 8, Windows 8.1, Apple Mac OS X 10.9, Apple Mac OS X 10.10, Windows 10
Software Included
Drivers & Utilities
Power Consumption Standby
2.2 Watt
Power Consumption Sleep
0.69 Watt
USB cable
Consumables Included
1 x Cartridge (black) - up to 120 pages - HP 65 , 1 x Cartridge (tricolour) - up to 100 pages - HP 65
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - 1 year
40.3 cm
17.7 cm
14.1 cm
2.33 kg
Shipping Weight
3.34 kg
5 °C
15 - 80% (non-condensing)
