A compact all-in-one, the HP Deskjet 3634 is designed to fit on your desk, on a shelf, or anywhere you need it. With an intuitive control panel, LCD display and user-friendly features, you can print, scan and copy with ease. Wireless direct printing enables you to connect your mobile device directly to the printer without accessing a network. Using the free HP All-in-One Printer Remote mobile app you can manage printing tasks and scan directly from smartphones and tablets. The HP Deskjet 3634 uses HP’s lowest-priced ink cartridges to deliver consistent, high-quality results. It also features a quiet mode for noise-sensitive environments and delivers borderless printing up to A4 size.
Recycle today for a better tomorrow
Easily recycle your Original HP ink and toner cartridges for free. -
Easy mobile printing from HP
Easily print from your smartphone, tablet, and notebook at work, home or on the go. -
Remote control for your printer
Manage your all-in-one or MFP from your smartphone or tablet, using the HP All-in-One Printer Remote app. -
On-the-go printing with HP ePrint
Print photos, documents and more when you're on the go, using HP ePrint. -
Borderless printing
Borderless photos are printed right to the edge of the paper. You get beautiful photo prints with no trimming!
- HP Deskjet 3634 All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- English / United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 100 - 250 pages
- Max Copying Speed
- Up to 5 ppm (mono) / up to 3.5 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 8.5 ppm (mono) / up to 6 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 60 sheets
- Output Trays Capacity
- 25 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- HP Auto Wireless Connect, automatic paper sensor, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 43.8 cm x 31 cm x 15.8 cm
- 4.17 kg
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- 1000 pages
- 100 - 250 pages
- Display Features
- 7 segment LCD display with icons
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
Copying
- Max Copying Speed
- Max Document Enlargement
- 200%
- Max Document Reduction
- 25%
- Maximum Copies
- 9
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 328 nozzles (black), 588 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI, PCLm, URF
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 17 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76 x 127 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- 60 sheets
- 25 sheets
- Input tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 8.5 ppm - B/W (ISO) , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 6 ppm - colour (ISO) , Printing: up to 16 ppm (Letter A) - colour draft , Printing: up to 16 ppm (A4) - colour draft , Copying: up to 5 ppm (A4) - B/W (ISO) , Copying: up to 3.5 ppm (A4) - colour (ISO)
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10
- Software Included
- Drivers & Utilities, HP Photo Creations
- Voltage Required
- 10 Watt
- Power Consumption Standby
- 2.1 Watt
- Power Consumption Sleep
- 0.88 Watt
- Included Accessories
- USB cable
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 63 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 63
- GOST, Directive 1999/5/EC, KCC, FCC CFR47 Part 15 B, VCCI V-2, EN 61000-3-3:2008, NOM-019-SCFI-1993 IRAM, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, ICES-003 issue 5 Class B, CNS13438:2006, CNS 14336, LVD 2006/95/EC, IEC 60950-1:2005 Second Edition, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, GB 4943.1-2011, EN 55022:2010 Class B
- ENERGY STAR Certified
- 43.8 cm
- 31 cm
- 15.8 cm
- 4.17 kg
- Shipping Width
- 47.5 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 35.4 cm
- Shipping Weight
- 5.09 kg
- Sound Emission
- 47 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
