Keep it simple with an affordable all-in-one you can count on. Stay connected with the easiest way to print from your smartphone or tablet. Quickly print, scan, and copy – right out of the box – and keep free of clutter with a space-saving design.
Recycle today for a better tomorrow
Easily recycle your Original HP ink and toner cartridges for free. -
Easy mobile printing from HP
Easily print from your smartphone, tablet, and notebook at work, home or on the go. -
Remote control for your printer
Manage your all-in-one or MFP from your smartphone or tablet, using the HP All-in-One Printer Remote app. -
On-the-go printing with HP ePrint
Print photos, documents and more when you're on the go, using HP ePrint. -
Borderless printing
Borderless photos are printed right to the edge of the paper. You get beautiful photo prints with no trimming!
- HP Deskjet 3630 All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- English / United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 100 - 250 pages
- Max Copying Speed
- Up to 5 ppm (mono) / up to 3.5 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 8.5 ppm (mono) / up to 6 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Automatic paper sensor, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 43.8 cm x 31 cm x 15.8 cm
- 4.17 kg
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- 1000 pages
- 100 - 250 pages
- Display Features
- 7 segment LCD display with icons
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
Copying
- Max Copying Speed
- Max Document Enlargement
- 200%
- Max Document Reduction
- 25%
- Maximum Copies
- 9
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI, PCLm, URF
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm)
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- Input tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 8.5 ppm (A4) - B/W (ISO) , Printing: up to 6 ppm (A4) - colour (ISO) , Copying: up to 5 ppm (A4) - B/W (ISO) , Copying: up to 3.5 ppm (A4) - colour (ISO)
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- Drivers & Utilities, HP Photo Creations
- Voltage Required
- 10 Watt
- Power Consumption Standby
- 2.1 Watt
- Power Consumption Sleep
- 0.88 Watt
- Included Accessories
- USB cable
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
- GOST, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
- ENERGY STAR Certified
- 43.8 cm
- 31 cm
- 15.8 cm
- 4.17 kg
- Shipping Width
- 47.5 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 35.4 cm
- Shipping Weight
- 5.09 kg
- Sound Emission
- 47 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
