HP Deskjet 2710e All-in-One Multifunction printer
Quicklinx: GSQCWS00 Mfr#: 26K72B#687
Simple setup. Simple printing.
Get started fast with simple setup that guides you through each step, using HP Smart app. Easily handle tasks and get a lot from one device – print, scan, and copy. Get quick and easy printing directly at the control panel. Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.
Worry-free wireless
Get better range and faster, more reliable connections using dual-band Wi-Fi® with self-reset.Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.Built-in wireless capabilities let you easily access, print, and share resources on a network
Never run out of ink with Instant Ink
Never run out of ink.Convenient ink cartridge replacements and smart delivery included. Save up to 70% with Instant Ink. Enroll to get ink, delivery and recycling starting at £0.99 a month. Peace of mind with plan flexibility to change or cancel anytime at no cost. Help us put plastic back into printers with prepaid recycling service included
HP+. HP's smart printing system.
A cloud-connected HP+ printer is smarter – it keeps itself up to date and ready to print. First 6 months of Instant Ink included; after 6 months, monthly fee charged automatically unless cancelled. Print and scan from the palm of your hand. Enjoy advanced productivity features for 2 years with HP+. HP+ requires an HP account, ongoing internet connection, and use of Original HP ink cartridges.
  • Print, copy, scan
  • Colour
  • 10 x 15 cm; A4; Envelopes
  • Print speed up to 7.5 ppm (black) and 5.5 ppm (colour)
  • Wireless; HP+; HP Instant Ink eligible; Print from phone or tablet
  • For teams up to 3 users; Prints up to 100 pages/month
  • Seamless setup
    Get started fast with simple setup that guides you through each step, using HP app.
  • Your reliable connection
    Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Printing from your smartphone just got easier
    Easily print everyday documents from your smartphone, using HP app.
  • Amazing scanning, now on your smartphone
    With HP app, get high-quality scanning and sharing – plus easily make copies – from your smartphone.
  • Tackle the essentials
    Get versatile performance and print, scan, and copy.
  • HP+, the cloud-connected, smart printing system
    An HP+ printer is ready when you are, more secure and productive than ever.
HP Deskjet 2710e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 100 pages
Max Copying Speed
Up to 6 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed
Up to 7.5 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
60 sheets
Max Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Bluetooth, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Instant Ink, print from mobile devices, scan to PDF
AC 120/230 V (50/60Hz)
42.5 cm x 30.4 cm x 15.4 cm
3.42 kg
Enclosure Colour
White
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
50 - 100 pages
Display Features
Icon LCD display
AirPrint Enabled
Enclosure Colour
White
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PCLm, URF
First Print Out Time B/W
15 sec
First Print Out Time Colour
19 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
145 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 89 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
Max Media Capacity
60 sheets
25 sheets
Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 145 lbs , Output tray - 25 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Copying: up to 6 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, Windows 10, macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
Software Included
Drivers & Utilities, HP Smart App
Power Consumption Standby
2.5 Watt
Power Consumption Sleep
1.1 Watt
FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6 Class B, EN 301 489-17 V3.1.1 (2017), CISPR 35, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited warranty - 1 year
42.5 cm
30.4 cm
15.4 cm
3.42 kg
Shipping Width
47.5 cm
Shipping Depth
35.4 cm
Shipping Height
19.1 cm
Shipping Weight
4.58 kg
Sound Emission
48 dBA (operating)
5 °C
15 - 80% (non-condensing)
Ink (2)
GSQC HP 305XL High yeild black orginal In Stock £18.39
GSQC HP 305XL High Yield Tri-Color Origin In Stock £16.84
Other bundles (1)
GSQC HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £17.19
