HP DeskJet 2132 Colour InkJet Multifunction Printer
Quicklinx: BT60WS00 Mfr#: K7N78B#BEV
Make your everyday printing, scanning, and copying easy with an HP DeskJet all-in-one that simply works - right out of the box. Save money with optional high-yield ink cartridges. Plus, save space with an all-in-one designed to fit where you need it.
  • Recycle today for a better tomorrow
    Easily recycle your Original HP ink and toner cartridges for free.
HP Deskjet 2132 All-in-One - multifunction printer - colour
Multifunction printer
English / United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 200 pages
Max Copying Speed
Up to 5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 7.5 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
89 x 127 mm (min) - A4 (210 x 297 mm), 215 x 279 mm (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0
AC 120/230 V (50/60Hz)
42.5 cm x 30.4 cm x 14.9 cm
3.42 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
50 - 200 pages
USB 2.0
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
89 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 215 x 279 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
25 sheets
Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 7.5 ppm (A4) - B/W (ISO) , Printing: up to 5.5 ppm (A4) - colour (ISO) , Copying: up to 5 ppm (A4) - B/W (ISO) , Copying: up to 3 ppm (A4) - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Drivers & Utilities
10 Watt
Power Consumption Standby
1.9 Watt
Power Consumption Sleep
9 Watt
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 63 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 63
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
42.5 cm
30.4 cm
14.9 cm
3.42 kg
Shipping Width
47.5 cm
Shipping Depth
19.1 cm
Shipping Height
35.4 cm
Shipping Weight
4.48 kg
Sound Emission
48 dBA (operating)
5 °C
20 - 80%
BT60 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
BT60 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
