HP DeskJet 2130 Colour Ink-Jet All-in-One Printer
Quicklinx: BL4RWS00 Mfr#: F5S40B#BEV
Make your everyday printing, scanning and copying easy with an HP DeskJet all-in-one that simply works – right out of the box. Save money with optional high-yield ink cartridges. Plus, save space with an all-in-one designed to fit where you need it.
  • Get just what you need – right away
    Count on easy versatility. Print, scan and copy what you need quickly with a reliable all-in-one.
  • It's easy from the start
    Get started in fewer steps. Easily set up this all-in-one to print, scan and copy with simple controls.Save your space with a compact all-in-one designed to fit on your desk, on a shelf or anywhere you need it.
  • Tackle more tasks affordably
    Print more for less, using the world's No. 1 printer brand plus Original HP ink cartridges.Full of value – print up to twice as many pages with Original HP high-yield ink cartridges.
  • Reduce your impact
    Conserve resources without sacrificing performance with an all-in-one that's ENERGY STAR certified.Reduce your environmental impact – count on easy, free cartridge recycling through HP Planet Partners.
HP Deskjet 2130 All-in-One - multifunction printer - colour
Multifunction printer
English / United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 200 pages
Max Copying Speed
Up to 5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 7.5 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
89 x 127 mm (min) - A4 (210 x 297 mm), 215 x 279 mm (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0
AC 120/230 V (50/60Hz)
42.5 cm x 30.4 cm x 14.9 cm
3.42 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 pages
50 - 200 pages
USB 2.0
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
89 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 215 x 279 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
25 sheets
Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Copying: up to 5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 16 ppm (10 x 15 cm (4"x6")) - photo draft , Printing: 66 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 16 ppm (Letter A) - colour draft
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Drivers & Utilities
10 Watt
Power Consumption Standby
1.9 Watt
Power Consumption Sleep
9 Watt
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
ENERGY STAR Certified
42.5 cm
30.4 cm
14.9 cm
3.42 kg
Shipping Width
47.5 cm
Shipping Depth
19.1 cm
Shipping Height
35.4 cm
Shipping Weight
4.48 kg
Sound Emission
48 dBA (operating)
5 °C
20 - 80%
BL4R HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.68
BL4R HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.69
