HP Deskjet 1110 Colour InkJet Printer
Quicklinx: BT5YWS00 Mfr#: F5S20B#BEV
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Print the documents you need in a snap. Designed to fit tight spaces and budgets, this printer is simple to set up and use right out of the box. Count on high-quality prints while also conserving energy with a printer that's ENERGY STAR certified.
  • Enjoy printing made simple
    No need to wait. Start printing right out of the box with easy setup.
  • Count on a product designed to fit your life
    Save your space with a compact printer designed to fit on your desk, on a shelf or anywhere you need it.
  • Experience affordable at-home printing
    Print more for less, using the world's No. 1 printer brand plus Original HP ink cartridges.Full of value – print up to twice as many pages with Original HP high-yield ink cartridges.
  • Reduce your impact
    Conserve resources without sacrificing performance with a printer that's ENERGY STAR certified.Reduce your environmental impact – count on easy, free cartridge recycling through HP Planet Partners.
HP Deskjet 1110 - printer - colour - ink-jet
Printer Type
Personal printer - ink-jet - colour
2.02 kg
English / United Kingdom, Ireland
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm), 215 x 279 mm
Min Media Size (Custom)
89 mm x 127 mm
Max Media Size (Custom)
215 mm x 297 mm
Print Speed
Up to 7.5 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 5.5 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
USB 2.0
Language Simulation
PCL 3
Media Type
Plain paper, photo paper
Total Media Capacity
60 sheets
Media Handling
60-sheet input tray
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 200 pages
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10
42.58 cm x 21.56 cm x 12.43 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Print Speed
Wired
USB 2.0
1200 x 1200 dpi
4800 x 1200 dpi
Language Simulation
PCL 3
Media Handling
60-sheet input tray
Media Handling
Media Type
Media Size Class
A4
Max Media Size
89 mm x 127 mm
215 mm x 297 mm
Media Sizes
A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Envelope Sizes
International DL (110 x 220 mm)
Media Weight
60 g/m² - 300 g/m²
60 sheets
Media Feeders
1 x automatic - 60 rolls - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
Output Trays Capacity
25 sheets
Duty Cycle
1000 pages
50 - 200 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
Power supply - internal
Frequency Required
50/60 Hz
10 Watt
Power Consumption Stand by
1.3 Watt
Power Consumption Sleep
0.7 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 7/8/8.1 - 1 GHz HD 2 GB , MacOS X 10.8/10.9/10.10 - HD 1 GB
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Operating)
55 dBA
42.58 cm
21.56 cm
12.43 cm
2.02 kg
Width (Shipping)
47.3 cm
Depth (Shipping)
16.3 cm
Height (Shipping)
27.4 cm
Weight (Shipping)
2.89 kg
