Print the documents you need in a snap. Designed to fit tight spaces and budgets, this printer is simple to set up and use right out of the box. Count on high-quality prints while also conserving energy with a printer that's ENERGY STAR certified.
Enjoy printing made simple
No need to wait. Start printing right out of the box with easy setup. -
Count on a product designed to fit your life
Save your space with a compact printer designed to fit on your desk, on a shelf or anywhere you need it. -
Experience affordable at-home printing
Print more for less, using the world's No. 1 printer brand plus Original HP ink cartridges.Full of value – print up to twice as many pages with Original HP high-yield ink cartridges. -
Reduce your impact
Conserve resources without sacrificing performance with a printer that's ENERGY STAR certified.Reduce your environmental impact – count on easy, free cartridge recycling through HP Planet Partners.
- HP Deskjet 1110 - printer - colour - ink-jet
- Printer Type
- Personal printer - ink-jet - colour
- 2.02 kg
- Localisation
- English / United Kingdom, Ireland
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm), 215 x 279 mm
- Min Media Size (Custom)
- 89 mm x 127 mm
- Max Media Size (Custom)
- 215 mm x 297 mm
- Print Speed
- Up to 7.5 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 5.5 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB 2.0
- Language Simulation
- PCL 3
- Media Type
- Plain paper, photo paper
- Total Media Capacity
- 60 sheets
- Media Handling
- 60-sheet input tray
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 50 - 200 pages
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10
- 42.58 cm x 21.56 cm x 12.43 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1200 x 1200 dpi
- 4800 x 1200 dpi
- PCL 3
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 89 mm x 127 mm
- 215 mm x 297 mm
- Media Sizes
- A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
- Envelope Sizes
- International DL (110 x 220 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 60 sheets
- Media Feeders
- 1 x automatic - 60 rolls - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
- Output Trays Capacity
- 25 sheets
Duty Cycle
- 1000 pages
- 50 - 200 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 10 Watt
- Power Consumption Stand by
- 1.3 Watt
- Power Consumption Sleep
- 0.7 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7/8/8.1 - 1 GHz HD 2 GB , MacOS X 10.8/10.9/10.10 - HD 1 GB
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Operating)
- 55 dBA
- 42.58 cm
- 21.56 cm
- 12.43 cm
- 2.02 kg
- Width (Shipping)
- 47.3 cm
- Depth (Shipping)
- 16.3 cm
- Height (Shipping)
- 27.4 cm
- Weight (Shipping)
- 2.89 kg
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £15.26 |
