Print vivid, eye-catching graphics and technical documents with HP chromatic red ink. Multi-roll operation and flexible workflows enable express printing. HP's optimized 6-ink printing system helps reduce ink consumption up to 20%.
Produce impressive, high-impact graphics—HP chromatic red ink creates eye-catching POP signs, posters. Print a versatile range of durable, lasting applications from GIS, maps, and technical drawings to photos, canvas.
Impressive—HP chromatic red ink enhances the color gamut—ideal for high-impact POP signs and posters. Versatile—with pigment-based photo inks for GIS, durable maps, technical drawings and photos, canvas. Reliable color, line accuracy—HP Professional PANTONE® color emulation, with Adobe® PostScript®/PDF, HP-GL/2. Durable—water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.
Simple, flexible operation. Automatic multi-roll printing boosts media loading efficiency up to 75%. Print up to 39% faster with quick-drying HP inks. Enjoy easy one-click printing. PostScript® and broad RIP choice support color workflows.
Boost operator media loading efficiency up to 75% with automatic multi-roll printing. Print up to 39% faster—save time on technical drawings with quick-drying HP Vivid Photo Inks. Easy—one-click printing, color touchscreen, print preview, direct USB flash drive, email printing. Flexible—supports color workflows with genuine Adobe® PostScript® and broad choice of RIPs.
Spend less time and help reduce operating costs. HP's optimized 6-ink printing system helps you reduce ink consumption up to 20%. Less operator attention is needed with 300-ml HP ink cartridges, optimized media usage, and no maintenance cartridge.
Up to 20% ink consumption savings using HP’s optimized 6-ink printing system. No maintenance cartridge—auto drop detection and nozzle switching reduce cleaning, maintain image quality. Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges. Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.
Eye-catching, water/fade-resistant images
Impressive-HP chromatic red ink enhances the color gamut-ideal for high-impact POP signs and posters.Versatile-with pigment-based photo inks for GIS, durable maps, technical drawings and photos, canvas.Reliable color, line accuracy-HP Professional PANTONE color emulation, with Adobe PostScript /PDF, HP-GL/2.Durable-water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.VIVID. -
Fast one-click, and multi-roll
Boost operator media loading efficiency up to 75% with automatic multi-roll printing.Print up to 39% faster-save time on technical drawings with quick-drying HP Vivid Photo Inks.Easy-one-click printing, color touchscreen, print preview, direct USB flash drive, email printing.Flexible-supports color workflows with genuine Adobe PostScript and broad choice of RIPs.EXPRESS PRINTING. -
Cut costs with HP 6-ink printing system
Up to 20% ink consumption savings using HP's optimized 6-ink printing system.No maintenance cartridge-auto drop detection and nozzle switching reduce cleaning, maintain image quality.Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges.Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.SAVINGS.
- HP DesignJet Z5600 PostScript - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- 86.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, matte black, photo black, chromatic red
- Max Media Size
- Roll (111.8 cm x 91 m)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 1118 mm x 1676 mm
- Print Speed
- Up to 60 sq.m/hour , Up to 48 sq.m/hour - colour draft , Up to 7 sq.m/hour - colour best , Up to 8.9 sq.m/hour - normal
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- USB 2.0, Gigabit LAN
- RAM Installed (Max)
- 640 MB
- Hard Drive
- 320 GB
- Language Simulation
- PCL 3, PostScript 3, CALS G4, HP GL/2, PDF, TIFF, HP PCL 3 GUI
- Media Type
- Photo paper, fabric, fine art paper, bond paper, proofing paper, banner paper, film, backlit paper, coated paper, self-adhesive paper
- Networking
- Print server
- 1-year warranty
- 177 cm x 77.5 cm x 105 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 2112 nozzles
- Ink Cartridge Configuration
- 6 individual ink tanks; 2 colours per print head
- Ink Type
- HP Vivid Photo Inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- Cutter
- Colour Management Features
- PANTONE Digital Color
RAM
- 640 MB
Storage
- Hard Drive
- 320 GB
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 1118 mm x 1676 mm
- Media Sizes
- Roll (111.8 cm x 91 m), 210 x 279 mm, 1118 x 1676 mm
- Media Weight
- 80 g/m² - 500 g/m²
- Media Feeders
- 1 x manual - 1 roll - Roll (111.8 cm x 91 m) weight: 80 g/m² - 500 g/m²
- Networking
- Print server
- Expansion Slots
- 1 x EIO
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
- Included Accessories
- Spindle, stand
- Consumables Included
- 6 x ink cartridge , 3 x printhead
- FCC Class A certified, CSA, GOST, CCC, PSB, IRAM, RoHS, EN 60950-1, KCC, WEEE, REACH, ICES Class A, LVD, EMC Class A, VCCI Class A
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 120 Watt
- Power Consumption Stand by
- 32 Watt
- Power Consumption Sleep
- 1.5 Watt
- Software Included
- Drivers & Utilities
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 22 dBA
- Sound Emission (Operating)
- 42 dBA
- 177 cm
- 77.5 cm
- 105 cm
- 86.5 kg
- Width (Shipping)
- 193 cm
- Depth (Shipping)
- 77 cm
- Height (Shipping)
- 72 cm
- Weight (Shipping)
- 119.5 kg
