Add high-profit, large-format prints with this HP Designjet and watch business grow. Impress with high-quality prints using HP inks, ColorPRO papers. Your workflow is faster and easier, and the printer supports more file formats than you might think.
Fast printing with an intelligent workflow
Print quickly with speeds up to 41 m /hr (445 ft /hr).Radically simplify and speed up your entire printing workflow with HP Instant Printing Pro.Preview, crop, and print PDF, PostScript, HP-GL/2, TIFF, JPEG and DWF files without opening applications.Shorten turnaround times with a 160 GB hard drive, borderless printing, and fast-drying HP Photo Inks. -
High-impact, long-lasting color prints
Impress your customers with high-impact color and black-and-white applications.Get rich, dark blacks on matte and glossy papers with matte black and photo black HP Photo Inks.Expand your offerings-HP Photo Inks produce water-resistant prints that last up to 200 years.Get color reliability with HP Professional PANTONE color emulation and Adobe Postscript /PDF support. -
Easy, unattended, and reliable operation
Avoid wasting time and money on trial and error with automatic color calibration thanks to the embedded spectrophotometer.Optimize performance, ink usage-automatic servicing routines help prevent nozzle clogging, reduce media waste.Save time with HP Printer Utility software-printer status communications, desktop alerts, automatic updates.Enable unattended printing-300-ml Original HP ink cartridges help reduce interventions.
- HP DesignJet Z5200 PostScript - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- 86 kg
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 8-ink
- Max Media Size
- Roll (111.8 cm)
- Min Media Size (Custom)
- 216 mm x 279 mm
- Max Media Size (Custom)
- 1118 mm x 1676 mm
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB, LAN
- RAM Installed (Max)
- 32 GB
- Hard Drive
- 160 GB
- Language Simulation
- PCL 3, PostScript 3, CALS G4, TIFF, PDF 1.6
- Media Type
- Photo paper, fabric, fine art paper, proofing paper, banner paper, film, backlit paper, coated paper
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.5, Citrix MetaFrame
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 177 cm x 69 cm x 104.7 cm
- Printer Type
Printer
- Inkjet Technology
- HP Thermal Inkjet
- 8-ink
- Ink Type
- HP Vivera Inks
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 2400 x 1200 dpi
- 2400 x 1200 dpi
RAM
- 32 GB
Storage
- Hard Drive
- 160 GB
Media Handling
- Media Type
- Max Media Size
- Roll (111.8 cm)
- 216 mm x 279 mm
- 1118 mm x 1676 mm
- Media Weight
- 500 g/m²
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x EIO
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0
- Included Accessories
- Spindle, stand
- CSA, VCCI, BSMI, GOST, CCIB, CCC, EMC, DOC, PSB, MIC, MOC, FCC, IRAM, EN 60950-1, ACA
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 170 Watt
- Power Consumption Stand by / Sleep
- 50 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- MacOS X - PowerPC G4 RAM 1 GB - HD 2 GB , Windows XP - Pentium 4 RAM 1 GB - HD 2 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 44 dBA
- 177 cm
- 69 cm
- 104.7 cm
- 86 kg
- Width (Shipping)
- 193 cm
- Depth (Shipping)
- 76.6 cm
- Height (Shipping)
- 76.9 cm
- Weight (Shipping)
- 123 kg
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.37 |
HP Special Inkjet Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £65.89 |
HP Coated Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £29.82 |
HP Bright White Inkjet Paper-914 mm x 45.7 m | In Stock | £24.94 |
