This 12-ink HP Designjet, with new HP 73 Chromatic Red ink, delivers long-lasting gallery-quality prints in black-and-white and colour. HP DreamColor Technologies with an embedded spectrophotometer enable easy calibration and profiling.
Wide color gamut and outstanding black-and-white
12 Original HP Photo Inks deliver gallery-quality black-and-white and color prints lasting up to 200 years.Create exceptional black-and-white prints-an HP Quad-black ink set delivers smooth transitions, neutral grays.Get superior gloss uniformity and minimize bronzing on most glossy photo papers with HP Gloss Enhancer.Achieve an expanded color gamut with 96% PANTONE coverage enabled by HP chromatic red ink. -
Easy color calibration and profiling
Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.See consistent print-to-print color regardless of fluctuating environmental conditions with HP technologies.Simplify your workflow- easily access, create, and share paper presets using the enhanced HP Color Center.Get color reliability with HP Professional PANTONE color emulation and Adobe Postscript /PDF support. -
Low-maintenance and high ink efficiency
Optimize performance, ink usage-automatic servicing routines help prevent nozzle clogging, reduce media waste.Save time, money-embedded TIFF, JPEG, and Adobe PS3/PDF RIP enable direct job submission, queuing, nesting.Streamline production with an HP Embedded Web Server and print previews, which help eliminate trial and error.Stay up-to-date-HP Printer Utility software provides printer status, desktop alerts, and automatic updates.
- HP DesignJet Z3200ps - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 65 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 12-ink
- Max Media Size
- Roll A1 (61.0 cm), Roll ARCH D (61 cm)
- Min Media Size (Custom)
- 216 mm x 279 mm
- Max Media Size (Custom)
- 610 mm x 1676 mm
- Print Speed
- Up to 2 min/page - colour fast - A1 (594 x 841 mm) , Up to 12.4 min/page - colour best - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB, Gigabit LAN
- RAM Installed (Max)
- 256 MB
- Hard Drive
- 80 GB
- Language Simulation
- PCL 3, PostScript 3, TIFF, PDF 1.6
- Media Type
- Photo paper, fabric, fine art paper, proofing paper, banner paper, film, backlit paper, coated paper
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Citrix MetaFrame, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 126 cm x 69 cm x 105 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- 12-ink
- Nozzle Configuration
- 12 x 1056 nozzles
- Minimum Ink Droplet Size
- 4 pl
- Ink Cartridge Configuration
- 12 individual ink tanks; 2 colours per print head
- Ink Type
- HP Vivera Inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
RAM
- 256 MB
Storage
- Hard Drive
- 80 GB
Media Handling
- Media Type
- Max Media Size
- 216 mm x 279 mm
- 610 mm x 1676 mm
- Media Thickness Range
- Up to 0.8 mm
- Media Weight
- 500 g/m²
- Media Feeders
- 1 x manual - 1 roll - Roll A1 (61.0 cm)
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x EIO
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
- Included Accessories
- Spindle, stand
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta) , 1 x ink cartridge (light grey) , 1 x ink cartridge (photo black) , 1 x ink cartridge (grey) , 1 x ink cartridge (gloss enhancer) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (matte black) , 1 x ink cartridge (chromatic red) , 1 x ink cartridge (green) , 1 x ink cartridge (blue) , 6 x printhead
- CSA, VCCI, BSMI, GOST, CCIB, CCC, EMC, DOC, PSB, MIC, MOC, FCC, IRAM, IEC 60950-1, EN 60950-1, ACA, LVD
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 200 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 49 dBA
- 126 cm
- 69 cm
- 105 cm
- 65 kg
- Width (Shipping)
- 147 cm
- Depth (Shipping)
- 78 cm
- Height (Shipping)
- 74 cm
- Weight (Shipping)
- 102 kg
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.37 |
HP Special Inkjet Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £65.89 |
HP Coated Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £29.82 |
