Easily produce vivid, eye-catching graphics and technical prints with a fast, compact printer with HP chromatic red ink. Flexible, intuitive operation helps save time. HP's optimized 6-ink printing system helps reduce ink consumption up to 20%.
Produce impressive, high-impact graphics—HP chromatic red ink creates eye-catching POP signs, posters. Print a versatile range of durable, lasting applications from photos and canvas, to GIS, maps, and technical drawings.
Impressive—HP chromatic red ink enhances the color gamut—ideal for high-impact POP signs and posters. Versatile—with pigment-based photo inks for photos, canvas, GIS, durable maps, and technical drawings. Reliable color, line accuracy—HP Professional PANTONE® color emulation, with Adobe® PostScript®/PDF, HP-GL/2. Durable—water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.
With flexible, intuitive operation, no training is needed to use this compact printer sized to fit your work space. Enjoy easy, one-click printing with HP DesignJet Click printing software. Print up to 3 times faster with quick-drying HP inks.
One-click printing, with HP DesignJet Click printing software, is easy for everyone. Flexible, intuitive—needs no training—color touchscreen, print preview, direct USB flash drive, email printing Print up to 3 times faster—save time using quick-drying HP Vivid Photo Inks. Fits your work space—this compact, space-saving printer is table mountable.
Spend less time and help reduce operating costs. HP's optimized 6-ink printing system helps you reduce ink consumption up to 20%. Less operator attention is needed with 300-ml HP ink cartridges, optimized media usage, and no maintenance cartridge.
Up to 20% ink consumption savings using HP’s optimized 6-ink printing system. No maintenance cartridge—auto drop detection and nozzle switching reduce cleaning, maintain image quality. Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges. Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.
Eye-catching, water/fade-resistant images
Impressive-HP chromatic red ink enhances the color gamut-ideal for high-impact POP signs and posters.Versatile-with pigment-based photo inks for photos, canvas, GIS, durable maps, and technical drawings.Reliable color, line accuracy-HP Professional PANTONE color emulation, with Adobe PostScript /PDF, HP-GL/2.Durable-water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.VIVID. -
Radically simple, fast, intuitive operation
One-click printing, with HP DesignJet Click printing software, is easy for everyone.Flexible, intuitive-needs no training-color touchscreen, print preview, direct USB flash drive, email printing.Print up to 3 times faster-save time using quick-drying HP Vivid Photo Inks.Fits your work space-this compact, space-saving printer is table mountable.EASY. -
Cut costs with HP 6-ink printing system
Up to 20% ink consumption savings using HP's optimized 6-ink printing system.No maintenance cartridge-auto drop detection and nozzle switching reduce cleaning, maintain image quality.Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges.Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.SAVINGS.
- HP DesignJet Z2600 PostScript - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 62 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, matte black, photo black, chromatic red
- Max Media Size
- Roll (61 cm x 45.7 m)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 610 mm x 1676 mm
- Print Speed
- Up to 43 sq.m/hour
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- USB 2.0, Gigabit LAN
- Hard Drive
- 160 GB
- Language Simulation
- PCL 3, PostScript 3, HP RTL, HP GL/2, PDF, TIFF, HP PCL 3 GUI
- Media Type
- Photo paper, fabric, fine art paper, bond paper, proofing paper, banner paper, film, backlit paper, coated paper, self-adhesive paper
- Networking
- Print server
- 1-year warranty
- 126 cm x 69 cm x 105 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 6 individual ink tanks; 2 colours per print head
- Ink Type
- HP Vivid Photo Inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- Cutter
- Colour Management Features
- PANTONE Digital Color
Storage
- Hard Drive
- 160 GB
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 610 mm x 1676 mm
- Media Sizes
- Roll (61 cm x 45.7 m), 610 x 1676 mm, 210 x 279 mm
- Media Weight
- 80 g/m² - 500 g/m²
- Media Feeders
- 1 x manual - 1 roll - Roll (61 cm x 45.7 m) 500 g/m²
- Networking
- Print server
- Expansion Slots
- 1 x EIO
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
- Included Accessories
- Spindle, stand
- Consumables Included
- 6 x ink cartridge
- FCC Class A certified, CSA, GOST, CCC, PSB, IRAM, RoHS, EN 60950-1, KCC, WEEE, REACH, ICES Class A, LVD, EMC Class A, VCCI Class A
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 120 Watt
- Power Consumption Stand by
- 32 Watt
- Power Consumption Sleep
- 1.5 Watt
- Software Included
- Drivers & Utilities
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 22 dBA
- Sound Emission (Operating)
- 44 dBA
- 126 cm
- 69 cm
- 105 cm
- 62 kg
- Width (Shipping)
- 144.2 cm
- Depth (Shipping)
- 77 cm
- Height (Shipping)
- 75 cm
- Weight (Shipping)
- 91.5 kg
