Product
HP DesignJet Z2600PS
Quicklinx: CP0RWS00 Mfr#: T0B52A#B19
Easily produce vivid, eye-catching graphics and technical prints with a fast, compact printer with HP chromatic red ink. Flexible, intuitive operation helps save time. HP's optimized 6-ink printing system helps reduce ink consumption up to 20%.
Produce impressive, high-impact graphics—HP chromatic red ink creates eye-catching POP signs, posters. Print a versatile range of durable, lasting applications from photos and canvas, to GIS, maps, and technical drawings.
Impressive—HP chromatic red ink enhances the color gamut—ideal for high-impact POP signs and posters. Versatile—with pigment-based photo inks for photos, canvas, GIS, durable maps, and technical drawings. Reliable color, line accuracy—HP Professional PANTONE® color emulation, with Adobe® PostScript®/PDF, HP-GL/2. Durable—water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.
With flexible, intuitive operation, no training is needed to use this compact printer sized to fit your work space. Enjoy easy, one-click printing with HP DesignJet Click printing software. Print up to 3 times faster with quick-drying HP inks.
One-click printing, with HP DesignJet Click printing software, is easy for everyone. Flexible, intuitive—needs no training—color touchscreen, print preview, direct USB flash drive, email printing Print up to 3 times faster—save time using quick-drying HP Vivid Photo Inks. Fits your work space—this compact, space-saving printer is table mountable.
Spend less time and help reduce operating costs. HP's optimized 6-ink printing system helps you reduce ink consumption up to 20%. Less operator attention is needed with 300-ml HP ink cartridges, optimized media usage, and no maintenance cartridge.
Up to 20% ink consumption savings using HP’s optimized 6-ink printing system. No maintenance cartridge—auto drop detection and nozzle switching reduce cleaning, maintain image quality. Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges. Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.
  • Eye-catching, water/fade-resistant images
    Impressive-HP chromatic red ink enhances the color gamut-ideal for high-impact POP signs and posters.Versatile-with pigment-based photo inks for photos, canvas, GIS, durable maps, and technical drawings.Reliable color, line accuracy-HP Professional PANTONE color emulation, with Adobe PostScript /PDF, HP-GL/2.Durable-water/scratch/fade-resistant and archivable prints last up to 200 years with HP Vivid Photo Inks.VIVID.
  • Radically simple, fast, intuitive operation
    One-click printing, with HP DesignJet Click printing software, is easy for everyone.Flexible, intuitive-needs no training-color touchscreen, print preview, direct USB flash drive, email printing.Print up to 3 times faster-save time using quick-drying HP Vivid Photo Inks.Fits your work space-this compact, space-saving printer is table mountable.EASY.
  • Cut costs with HP 6-ink printing system
    Up to 20% ink consumption savings using HP's optimized 6-ink printing system.No maintenance cartridge-auto drop detection and nozzle switching reduce cleaning, maintain image quality.Less operator intervention and more cost-effective printing with 300-ml HP ink cartridges.Optimize media usage by auto-arranging multiple images on a roll with HP DesignJet Click printing software.SAVINGS.
HP DesignJet Z2600 PostScript - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
62 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, matte black, photo black, chromatic red
Max Media Size
Roll (61 cm x 45.7 m)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
610 mm x 1676 mm
Print Speed
Up to 43 sq.m/hour
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, Gigabit LAN
Hard Drive
160 GB
Language Simulation
PCL 3, PostScript 3, HP RTL, HP GL/2, PDF, TIFF, HP PCL 3 GUI
Media Type
Photo paper, fabric, fine art paper, bond paper, proofing paper, banner paper, film, backlit paper, self-adhesive paper, coated paper
Print server
AC 120/230 V
1 year warranty
126 cm x 69 cm x 105 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
6 individual ink tanks; 2 colours per print head
Ink Type
HP Vivid Photo Inks
Print Speed
Up to 43 sq.m/hour
Built-in Devices
Cutter
Wired
2400 x 1200 dpi
2400 x 1200 dpi
PostScript Support
Standard
Language Simulation
Colour Management Features
PANTONE Digital Color
Storage
Hard Drive
160 GB
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
610 mm x 1676 mm
Media Sizes
Roll (61 cm x 45.7 m), 610 x 1676 mm, 210 x 279 mm
Media Weight
80 g/m² - 500 g/m²
Media Feeders
1 x manual - 1 roll - Roll (61 cm x 45.7 m) 500 g/m²
Print server
Expansion Slots
1 x EIO
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
Spindle, stand
Consumables Included
6 x ink cartridge
FCC Class A certified, CSA, GOST, CCC, PSB, IRAM, RoHS, EN 60950-1, KCC, WEEE, REACH, ICES Class A, LVD, EMC Class A, VCCI Class A
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
120 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
1.5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 80%
Sound Emission (Idle)
22 dBA
Sound Emission (Operating)
44 dBA
126 cm
69 cm
105 cm
62 kg
Width (Shipping)
144.2 cm
Depth (Shipping)
77 cm
Height (Shipping)
75 cm
Weight (Shipping)
91.5 kg
CP0R HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) In Stock £8.98
CP0R HP Heavyweight Coated Paper-610 mm x 30.5 m (24in x 100ft) In Stock £25.38
