HP's 8-ink Designjet delivers superior colour accuracy and consistency with the first-ever embedded spectrophotometer. Produce vivid, large format prints (up to 610 mm or 1118mm) in colour or black-and-white with 8 Original HP Photo Inks.
High-impact, long-lasting color prints
Produce vivid, high-quality color and black-and-white prints that impress your customers.Get rich, dark blacks on matte and glossy papers with matte black and photo black HP Photo Inks.8 Original HP Photo Inks deliver durable prints in color and blackand-white lasting up to 200 years.Save time with borderless printing and fast-drying HP Photo Inks. -
Easy color calibration and profiling
Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.See consistent print-to-print color regardless of fluctuating environmental conditions with HP technologies.Boost color accuracy-complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut.Supported by industry leaders, including EFI, X-Rite, GMG, ColorByte, Adobe, Creo, and Apple. -
Unattended operation with HP technologies
Optimize performance, ink usage-automatic servicing routines help prevent nozzle clogging, reduce media waste.Save time-HP Printer Utility software provides printer status, desktop alerts, and automatic updates.Get assistance-HP Color Center tool effortlessly guides you through color management and printing.Eliminate trial and error with real-time layout and orientation preview.
- HP DesignJet Z2100 - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- Form Factor
- Stationary
- 86 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Ink Palette Supported (Colours)
- 8-ink
- Max Media Size
- Roll (111.8 cm x 91.4 m)
- Max Media Size (Custom)
- 1117 mm
- Print Speed
- Up to 2 min/page - colour draft , Up to 4.2 min/page - colour normal , Up to 9.8 min/page - colour best
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB, LAN
- RAM Installed (Max)
- 128 MB
- Hard Drive
- 80 GB
- Language Simulation
- PCL 3
- Media Type
- Glossy photo paper, matt photo paper, bond paper, matte proofing paper, semi-gloss proofing paper, backlit paper, high-gloss proofing paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, self-adhesive vinyl, satin photo paper
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Apple MacOS X 10.3, Apple MacOS X 10.4 or later
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 177 cm x 69 cm x 104.7 cm
- Printer Type
- Form Factor
- Stationary
- Localisation
Printer
- 8-ink
- Nozzle Configuration
- 8 x 1056 nozzles
- Minimum Ink Droplet Size
- 4 pl
- Ink Cartridge Configuration
- 8 individual ink tanks; 2 colours per print head
- Ink Type
- HP Vivera Inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PCL 3
RAM
- 128 MB
Storage
- Hard Drive
- 80 GB
Media Handling
- Media Type
- Max Media Size
- 1117 mm
- Max Printing Length
- 91 m
- Media Weight
- 500 g/m²
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x EIO
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0
- Included Accessories
- Spindle, stand
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x ink cartridge (light cyan) - 69 ml , 1 x ink cartridge (light magenta) - 69 ml , 1 x ink cartridge (light grey) - 69 ml , 1 x ink cartridge (photo black) - 69 ml , 1 x ink cartridge (cyan) - 69 ml , 1 x ink cartridge (magenta) - 69 ml , 1 x ink cartridge (yellow) - 69 ml , 1 x ink cartridge (matte black) - 69 ml
- Media Included
- Roll of media
- CSA, VCCI, BSMI, GOST, BSMI CNS 13438 Class B, CCC, DOC, PSB, MIC, MOC, FCC, IEC 60950-1, EN 60950-1
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 200 Watt
- Power Consumption Stand by / Sleep
- 43 Watt
- OS Required
- System Requirements Details
- MacOS X 10.2 - PowerPC G4 RAM 1 GB - HD 2 GB , MacOS X 10.3 - PowerPC G4 RAM 1 GB - HD 2 GB , MacOS X 10.4 or later - PowerPC G4 RAM 1 GB - HD 2 GB , Windows 2000/XP - Pentium 4 - 3 GHz - RAM 1 GB - HD 2 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 49 dBA
- 177 cm
- 69 cm
- 104.7 cm
- 86 kg
- Width (Shipping)
- 196.5 cm
- Depth (Shipping)
- 78 cm
- Height (Shipping)
- 0.2 cm
- Weight (Shipping)
- 123 kg
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.37 |
HP Special Inkjet Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £65.89 |
HP Bright White Inkjet Paper-914 mm x 45.7 m | In Stock | £24.94 |
HP Coated Paper-1067 mm x 45.7 m (42in x 150ft) | In Stock | £55.96 |
